Rebuilding 1.8T
It's not going to be easy because you have to overcome the compression of the cylinders, but you shouldn't have to use a breaker bar either. I turned mine over with good two-handed grip on a 1/2" ratchet.
well I don't have the motor together and no pistons are in, I'm talking crank alone, torque'd to specs.
the crank should turn pretty easily with no pistons in. if it is turning hard, something is messed up. dont get me wrong. it takes maybe a pound or two of force to get it turning, but you should sense that it is in corretly. its prety tough to mess up bearings and the oil pump, but if you did it is very bad
