Reliable place to order new key and remote?
Old Feb 22, 2013 | 08:35 PM
markymarc's Avatar
Originally Posted by aidy76
hi and thanks for the reply i went to the boro town centre today and popped into a local key cutter he said he could cut me a key for 5 notes so i just need to order a blank key and fob of ebay but he said he doesnt program them is it possible to swap the inners of my fob and transfer in to the new one and does the fob im getting of ebay have to be exactly the same or could i order a newer looking fob sorry for being a pain but really dont know what to do lol ohh and yes the key i have opens the boot and glovebox hope this helps what is fcc id and how do i get the information to see if it is the right key many thanks aidy76
IF, and I say IF, you can move the 'inners' - go for it, but they are NOT hard to program and plenty of DIY on the web on how to do it, as well as you can do it with your VAG software as well.....FCC ID would be on inside of key fob as well.....
Old Jun 17, 2013 | 07:28 PM
ireniccontender's Avatar
Angry I am a 3 day old audi owner with one key
I appreciate the info shared but as has already been asked just need further guidance.
My 2003 Allroad Quattro manual is my first upscale car. Not used to all this fancy key stuff
Old Jun 17, 2013 | 09:32 PM
mtroxel's Avatar
Originally Posted by Cj3209
The VW guy thought there was some kind of immobilizer that would prevent my car from starting but it started.
US spec B5 Audi's never got the imobilizer. The B5 ran longer in the Passat, so it may be that later B5 VW's had it.
So when guys are talking about programing the key, they're just talking about programing the remote part of the fob. The key fob has the immobilizer chip in it, but a US B5 Audi doesn't see it.
Old Jul 21, 2013 | 10:05 AM
newtonhubcap's Avatar
I have a 98 A4 which I recently got. Keyfob does not work so I replaced the CR1620. Attempted to reprogram as has been discribed but no success. Not being able to reprogram with new batteries does that mean the fob is non-functional?
Thanks
Old Jul 21, 2013 | 10:23 AM
mtroxel's Avatar
Thanks
A lot of auto parts stores have a tester. Point your remote at it and it will tell you if there is a signal. If you pass that test, here's the programing procedure:
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second key.
3. Using the remote control press the Unlock button once, and the horn willsound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except on the first press, you press the unlock button 2, 3 or 4times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Old Jul 22, 2013 | 10:28 AM
A4TurboGuy's Avatar
Not to thread jack, but how do you get the FOB apart w/o breaking anything? Mine is not "switch-blading" as it should be. Sometime it does, sometimes it doesn't and it's pissing me off. Has anyone had this problem and been able to diy it? Thanks Guys.
Old Jul 22, 2013 | 02:21 PM
mtroxel's Avatar
You slide it apart. It's in two pieces and you can see a little spot where you can pry to lift the latch apart, then it slides apart. Then you pry the little 4 ring logo off the half that just holds the key itself, and you'll see a little screw underneath it. Voila!
On mine, part of the little plastic that switchblade pivots in was broken. See the pic. This is very small stuff, but with some tweezers and some carefully placed epoxy, I glued it back together. You cannot get epoxy in the circular channel where the switchblade pivots. But if some leaks out, if you wait till its pretty gummy, but not fully hardened, you can scrap it out with a small, jeweler's screwdiver.
Broken:
Glued back together:
Old Jul 23, 2013 | 08:27 AM
  #18
A4TurboGuy's Avatar
Ahh! Thank you Sir!
Old Aug 22, 2013 | 05:58 PM
  #19
SashaBond's Avatar
Question how many original keys needed to program extra key?
you described programming with two keys, but it is not clear where to use blank fob key...., can please specify? :
You'll need two keys (originals?).
1) Open the driver door, turn the ignition switch to on [first orig key], but do not start the car.
2) Close and lock the driver door with the other key (this should be the proper key and not just the valet key - I used the valet key first and wondered why the programming didn't work) [second orig key].
3) Hold down both buttons on the fob for about 5 seconds [on both orig keys]. The lights should flash and the alarm horn may honk.
4) Turn key [second orig key] to unlock the door. Take out key and open the door.
4) Remove the key from the ignition [first orig key] and put in new key[blank fob] and turn ignition switch to ON. Take out key, Close and lock the door with the key [blank fob].
if the above is correct that means that it is impossible to self program with only one original key...
Old Aug 22, 2013 | 07:51 PM
  #20
mtroxel's Avatar
I'd put it this way:
1) Open the driver door, turn the ignition switch to on [orignalkey], but do not start the car.
2) Close and lock the driver door with the other key (thisshould be the proper key and not just the valet key - I used the valet keyfirst and wondered why the programming didn't work) [new key].
3) Hold down both buttons on the fob for about 5 seconds [youare standing outside the car now, so this is the new key]. The lightsshould flash and the alarm horn may honk.
4) Turn key [new key] to unlock the door. Take outkey and open the door.
4) Remove the key from the ignition [original key]and put in new key[new fob] and turn ignition switch to ON.Take out key, Close and lock the door with the key [new key].
I think if you follow what I said above now, you only need one original key, and one key that is keyed for the lock cylinder on the driver's door. The process programs the radio part of the key. You only need a key in the ignition turning it on, then you sort of lock yourself out of the car while you program the radio part of the new key.
