remove tps or not
Old Feb 11, 2016 | 09:00 PM
nlinesk8s's Avatar
Default remove tps or not
I'm doing a rear bearing, and I'm confused about something. Some of the diys say to remove the tps sensor, some dont. If I'm using tooling to remove the bearing, why bother removing the sensor? ECS tool instructions say to remove, but the diys where you take the hub to a machine shop, you don't remove.
Old Feb 11, 2016 | 09:02 PM
nlinesk8s's Avatar
Default abs not tps- Im tired
ABS not tps,
Old Feb 11, 2016 | 09:26 PM
elduderino200's Avatar
I think it's more of a safety instruction. To do it the "exact" way instead of cutting corners. But if you can cut that corner and know you're not going to harm it (and therefor need to buy a new one) you're probably fine.
Old Feb 12, 2016 | 06:19 AM
nlinesk8s's Avatar
Thanks. I wish the instructions had been a little better. When they say remove something, its usually required. In this case a better instruction would be that's its advised, but you'll probably destroy the sensor if you try. Would have saved a $100 sensor knowing that. Oh well, 20 20 hind sight.
Old Feb 12, 2016 | 02:07 PM
Crap sorry.
carlv
Apr 23, 2008 04:22 AM
calvarenga
Oct 3, 2007 08:14 PM
RCFerrari
Apr 30, 2006 01:22 PM
RCFerrari
Apr 29, 2006 06:37 PM
smythe
Jun 3, 2005 09:12 AM
