Removed gauge cluster, odometer not lit anymore
Old Apr 25, 2010 | 04:32 PM
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Default Removed gauge cluster, odometer not lit anymore
I installed some gauge rings a couple days ago and when I put my cluster back in the odometer screen isn't lighting up anymore. I pulled the cluster back out and all the connections were made properly on the back.
I did a search and found some threads saying that a wire is probably broken inside, while someone else said it could be a blown fuse.
Have any of you had this problem and found a solution? I'm really hoping its not something broken internally.
Old Apr 25, 2010 | 05:21 PM
dragonrage's Avatar
I assume it could also be a bad lamp.
Old Apr 25, 2010 | 06:55 PM
FASTER's Avatar
Tech Slut
I would think the whole cluster would only have one fuse but you never know. Check the diagram in your manual.
Old Apr 26, 2010 | 04:39 PM
Will do. Man, nothing ever just works does it?
nolalbc
Oct 6, 2012 12:44 PM
jamesokane
May 1, 2012 09:06 AM
one.8TEE
Oct 10, 2010 07:26 PM
chanrith
Feb 23, 2007 12:16 AM
