Removing two piece headlights????????
Old Nov 3, 2009 | 07:35 PM
zscraig's Avatar
Member
Default Removing two piece headlights????????
I am frustrated with this one. How do you get these suckers out? I see the two torx bolts on top but no other bolts. I have a 1998 a4 1.8t so all of the B6 write-ups or the facelift write-ups are no good to me. Anybody have a picture or something or am I going to have to get dirty and rip the bumper off?
Old Nov 3, 2009 | 07:46 PM
aledelic42's Avatar
theres another bolt, it's like right under where the headlights and corners connect. if you have the right tools you should be able to get it out fine but if not you might need to remove the bumper
Old Nov 3, 2009 | 08:23 PM
zscraig's Avatar
Member
It's under? So I WON'T be able to see it just by looking from above? You know if it's another torx bolt?
Old Nov 3, 2009 | 08:41 PM
CCA4's Avatar
Old Nov 3, 2009 | 09:01 PM
NickBroderick's Avatar
What year is your car? You don't have to remove the bumper if you have a '96. I don't remember what year it started where they put the bolt underneath, but like Aledelic said, it's right between the corner and main piece. It's another torx bolt.
Old Nov 3, 2009 | 11:13 PM
ImTheDevil's Avatar
I have a 99 and didn't remove it either. I put the torx bit (T30 I believe) on a 12" extension and just went at it - no damage to bumper and the bolt came out.
Old Nov 3, 2009 | 11:35 PM
zscraig's Avatar
Member
Well I guess I'll give it another go tomorrow when it's light out. I seriously looked for the third torx bolt for 15 min and could not find it. Some say bumper can stay on, CCA4's write up says the bumper has to come off to remove it. I think the bumper will have to come off. Pain the in *** to do that just to change the corner lights.
Old Nov 3, 2009 | 11:39 PM
ImTheDevil's Avatar
Wait, are you just taking out the corners? Your posts sounded like the headlights were coming out. They're what are held by the torx bolts. The corners are easy - look behind the corners - the fender framework has a hole in it. Look down in, and you'll see a yellow/white plastic flat piece slid in on the side of the headlight housing. At the rearmost end is an upturned lip that clips against the headlight's guide rail (sounds like Greek but when you see it you'll know it). Push down on that with a screwdriver to pop it free, and pull the corner light straight out forward. Then you'll see the third headlight torx bolt underneath, if those are coming out too.
Old Nov 4, 2009 | 11:46 AM
zscraig's Avatar
Member
Haha I feel like an idiot. Thanks for the input guys. It just unclips and slides right out as ImTheDevil said.
Old Nov 4, 2009 | 12:27 PM
Midniteoyl's Avatar
Devils the man!.. Mines been kinda loose for awhile.. found the clip, and viola!
Tourbo24
Oct 16, 2010 12:19 PM
jhanson25
Jul 20, 2010 09:41 PM
xxramezyxx
May 25, 2009 03:49 PM
rCc0la
May 10, 2009 02:50 AM
brent07
Feb 4, 2006 07:18 PM
