Replaced the MAF and still acting funny
Old May 23, 2012 | 05:25 PM
johnson90512's Avatar
Default Replaced the MAF and still acting funny
So, I replaced the maf because i was told by several people that know cars and audis, that my MAF seemed to be bad by the symptoms..well i replaced that today...and it still acts weird. When going to rev up the rpms dip before they actually go up, and if I try and push the pedal past half way the engine bogs down and hesitates for about 3 seconds then drives fine, then after about 15 minutes of driving the car goes into what seems like limp mode and wont rev higher than like 1.75k rpms . Also, if my memory serves me well this started up after an oil based drop in filter. Any ideas are greatly appreciated
Old May 23, 2012 | 05:30 PM
M5S5's Avatar
Tech Certified
You will go broke replacing parts on your car with out diagnosing the problem. The fuel pressure is?
Are there any fault codes stored in the ecm?
What is the fuel trim?
Replacement of parts without a diagnoses is like letting a blind person drive.
Old May 23, 2012 | 05:47 PM
I am actually not sure about either of those, nor am I really sure how to find that info out...any ideas? ill look at the fault codes if there are some tonight t
Old May 23, 2012 | 06:10 PM
ImTheDevil's Avatar
Try a throttle body adaptation as well - the search feature will locate the procedure for you.
Old May 23, 2012 | 07:17 PM
CCA4's Avatar
I've heard of people having issues with over-oiled K&N cone filters, but never a drop-in panel filter before. What motor is in your car? What kinda shape are the vac lines in?
Old May 24, 2012 | 12:33 PM
Brochacho's Avatar
I had similar problems when replacing my MAFS. The problem ended up being, I when cheap and bought a cheap MAFS. I dished the money for a Bosch MAFS, and my b5 went completely back to normal.
What brand MAFS did you use?
Old May 24, 2012 | 02:55 PM
I bought a Hitachi, it was a direct replacement of what was on the car. I do have a fault code for a tps saying the signal is too low. p1022 and I can't do a Throttle Alignment in Vag com it just says group not abailable. Is there any way to test the MAF? or anything like that
Old May 24, 2012 | 03:16 PM
ImTheDevil's Avatar
I had the exact same code for throttle signal too low. Did a TBA with the key, then did it in Vagcom and it worked. What value in Vagcom are you using to force the TBA? I found on my 99 30v, which is cable-driven, that I need to use the 098 value for a dbw car. The cable-driven cars often need to use 060 to do the TBA. Do it with the key, cycling the ignition, and then try Vagcom again. If one of the above values gives you an error, use the other.
Old May 24, 2012 | 03:23 PM
Juan Fernandez's Avatar
sorry guys for posting this here but can some one tell me how to open a new threat? im new here in this forum and i cant find the option, thanks in advance and sorry again
Old May 24, 2012 | 03:35 PM
CCA4's Avatar
In the upper left hand corner of the B5 forum page there's a grey button that says "New Thread." Go to the right of that and use the search feature first
ColbyMn
Mar 11, 2012 08:33 PM
prady
Aug 5, 2011 05:07 PM
treyg
Feb 10, 2011 09:54 PM
99A4NOW
Dec 23, 2008 10:19 AM
JDCrowe
Feb 22, 2006 04:03 PM
