Replacing a/c discharge hose
Old Mar 23, 2013 | 10:32 PM
audinoob27's Avatar
Default Replacing a/c discharge hose
any help on replacing an a/c discharge hose. I mainly need a picture of the hose and i will be able to get to it. How hard is it going to be to replace? the system is already empty because there is a giant hole in the hose and all the refrigerant came out. thanks in advance for any help.
Old Mar 24, 2013 | 02:48 PM
jeckel20003's Avatar
Old Mar 25, 2013 | 02:05 PM
audinoob27's Avatar
thank you that will help alot but it in replacing it. but it still doesnt tell me which one is the discharge hose. i had a shop find the leak but they never told me which hose it was
Old Mar 25, 2013 | 05:47 PM
hartsoe1's Avatar
I'll play along and try some deductive reasoning. I think line 4 is the discharge.
Compressed stuff goes to the condenser up front, where it dumps heat to the outside environment. Then it goes past the 'high side' port 38B and into the car where it evaporates and takes heat out of the car as it changes state (liquid to gas). On the way back out it passes the charge port, which is really all I needed to know, to guess this is the 'low side.'
Am I correct?
Old Mar 25, 2013 | 08:42 PM
audinoob27's Avatar
nvm i quit being an idiot and figured it out. thanks for the help! the diagram is what did it for me. I don't know much about a/c so hart your explanation went wayyyy over my head haha, but the help is still much appreciated.
Old Mar 26, 2013 | 12:40 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
Harts description is right on flow, but the diagram was hard to read, he meant hose #5 I'm pretty sure. The discharge side (low pressure side) is after the high pressure gas expands after the orrifice 6a into the evaporator (not shown) but inside the car by the heater core. The high pressure liquid turns into a gas and is then low pressure. If I remember correctly, low pressure hoses are always larger in diameter because of this. So, the low pressure hose #5 that it sounds like you may need is p/n 8D0-260-707-AJ for 319.00 retail and 237.34 plus shipping your price. Takes about 1.5 weeks to get to you once ordered. Possibly faster if you are on the west coast.
Old Mar 26, 2013 | 06:20 PM
audinoob27's Avatar
he was right with #4 I found out. I bought the hose and matched them to the discription. i would say that was a good price for the hose but i get parts at cost because i work at a auto center.
audinoob27
Jul 4, 2012 01:30 AM
a3cracken
May 1, 2012 04:48 PM
burt_girth
Aug 1, 2006 06:13 PM
dasipher
Jul 23, 2006 05:06 PM
jimmysA4T
Oct 23, 2005 02:31 AM
