reverse lights out.
Old Mar 18, 2013 | 09:52 AM
phatjames167's Avatar
Default reverse lights out.
I tested the bulbs, they are ok. i didn't see a reverse light in my fuse list but it may have said backup lamp and i didn't realize it so I haven't checked a fuse yet.
in my searching it sounds common that a switch on the transmission goes out but from what I've seen they all say automatic or don't say if its related to a manual transmission. Also I', trying to find where on the car it is actually located. It doesn't sound like i don't have to get under the car to do this. is anyone able to give me any advise on this?
Also i installed 55w ballasts and 8k hid's last week, I'm not sure if they stopped working before or after. I know they did work recently though.
Old Mar 18, 2013 | 08:54 PM
ImTheDevil's Avatar
Check the fuses first. You're thinking of the neutral safety switch I believe, and it should be near the top of the transmission - during a clutch change, I was able to unplug all the harnesses by reaching down under the coolant reservoir to the trams, so it can probably be changed that way.
Old Apr 9, 2013 | 03:57 PM
alig@37.com's Avatar
No Reverse Light
Hi all I recently bought an Audi A4 2001 auto 2lt Petrol Saloon (Modal:B5) 8E5 Series.
When the car is put into reverse no light. Basic checks done as follows :
> All fuses in the car by the driver side dash board all checked OK.
> Related bulbs all swapped around with working ones and checked OK.
> Car has been lifted onto a Ramp to check reverse switch, but unable to locate the switch on the Auto gearbox. Audi main dealers unable to confirm if this car has a reverse switch on the gear box or not.
> The gearbox illumination board under the gearstick has been reseated, all related lights working correct.
Need your input. If all the basic t-shooting as above has been carried out all I have left is to get it checked by an auto electrician which costs an arm & a leg. I am car savey so can check out any suggestions. I would appreciate any assistance anyone may advise. Thanks to all in advance. Al
Old Apr 9, 2013 | 03:58 PM
No Reverse Light
frankm98402
Audi Q5
Aug 23, 2012 02:48 AM
Tourbo24
Sep 15, 2010 11:09 PM
zwickau
May 17, 2009 03:55 AM
pasta
Jan 7, 2009 09:15 AM
Kamikaze
Apr 12, 2007 12:53 AM
