Screw murphy and his law
Old Mar 8, 2011 | 05:57 PM
DOC_DEPALMA's Avatar
Default Screw murphy and his law
The tubes that supply coolant to the heads... I just broke one of the two mounting bolts clean in half
how the **** am I gonna get it out?
Old Mar 8, 2011 | 10:37 PM
RandomAudiOwner's Avatar
If it's a clean break then you will need to drill a smaller diameter hole into the broken bolt, then use a tool to get it out. Alternatively I would just drill it out roughly the same size and run a tap through it. Don't drill too deep in either case.
http://www.matcotools.com/Catalog/to...ype=T&cat=2469
I have the 4th set down, it works fairly well. But with any of these problems, ymmv. Just be careful. and don't wrench so hard next time!
Old Mar 9, 2011 | 06:32 AM
bradtyler02's Avatar
Based on my very limited knowledge of the 2.8, I think what you're talking about is a coolant flange on the back of the engine? My car sat for quite a while when this happened to me (I have a 1.8T)... you know what worked? Use a dremel tool to carefully cut a slot into the busted off screw. You may have to "scratch" the head a little... then insert a flat head screwdriver bit (or a stubby) and unscrew it.
Old Mar 9, 2011 | 12:13 PM
FASTER's Avatar
Tech Slut
^^^ LOL Brad I knew you'd chime in.
Old Mar 9, 2011 | 07:44 PM
2 or 3 months I went without my car, messing with the damn thing until that idea worked.
Amybc96
B7 Models
Jun 29, 2015 07:37 PM
mjmssline
B7 Models
May 30, 2010 12:29 PM
audia6s
Apr 16, 2008 05:33 PM
A4orced
Feb 11, 2006 03:06 PM
dudley doright
Feb 7, 2005 12:41 PM
