Seat belt chime removal vag-com code?
Old Aug 19, 2010 | 02:29 AM
morpheous's Avatar
Default Seat belt chime removal vag-com code?
I am playing around with my 3rd party usb vag-com cable,i programmed my keyless fob to close all 4 windows and the sun roof,when i hold down the lock button for 3 seconds,then to open all 4 windows,when i hold the open button.
I also programmed the fob to open all 4 doors and the trunk lock to open with 1 button press,instead of 2 button presses. also all 4 doors lock,when i reach 15mph and all the doors open,when i take the key,out the ignition.
I need the code to stop the seat belt chime from sounding off,when i turn the key to the on position. I tried to search the forum,via the search feature but i found nothing.
Here is a youtube video of what i have done,so far. http://www.youtube.com/watch?v=mD4Jdk340FY onepoint8tee.....this ones for you baby!
Old Aug 19, 2010 | 08:34 AM
cantdrive55's Avatar
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
Look at the third digit in the coding (Market version):
0 - "Germany" 24 hour clock
1 - "Rest of World" 24 hour clock
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock
Look at the fourth digit in the coding (Cylinders):
4 - 4-cylinder
6 - 6-cylinder
Look at the fifth digit in the coding (Distance impulse multiplier):
0 - TDI Engine (non-USA models)
2 - Non-turbo Gasoline engine
4 - Turbocharged engine
So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362.
A complete instrument cluster coding chart which includes 2000 and newer cars is available in the Ross-Tech Wiki.
http://www.ross-tech.com/vag-com/cars/audiB5.html
Old Aug 19, 2010 | 11:02 AM
morpheous's Avatar
Originally Posted by cantdrive55
[Select]
[17 - Instruments]
[Recode - 07]
[Do It!]
4 - 4-cylinder
6 - 6-cylinder
I am having a hard time,using the conversion chart,can someone help me out on how to compile the code to disable the seat belt chime sound?
Old Aug 22, 2010 | 03:37 AM
fdjetman's Avatar
Write down your existing 5-digit code
From above: +02 - Seatbelt warning active
subtract 2 from the first two digits of your existing 5-digit code. That's the new code to input.
Example: If existing 5-digit code is 07244
07 - 02 = 05
New 5-digit code: 05244
Old Aug 22, 2010 | 02:04 PM
morpheous's Avatar
07 - 02 = 05
I thought the + would mean to "add" not subtract?
"So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362." see what i mean? it says to "add" not subtract,like you said to do in your response.
Old Aug 22, 2010 | 02:44 PM
Dallas09's Avatar
That chart shows the + with an "active" seatbelt chime, so subtracting 02 would make it inactive.
Old Aug 23, 2010 | 01:46 AM
morpheous's Avatar
Recode for warning lamps through 1999 only:
select 17 instruments
recode - 07
02244 is my default code,i changed it to 02444 and it didn't cut off the seatbelt chime but it turned off the chime,when the driver door is open,not what i was going for but close.
what am i doing wrong? I am adding 2 and subtracting 2 to my default value and no joy
Old Aug 23, 2010 | 01:24 PM
Dallas09's Avatar
Yeah mine would turn of the seatbelt light, but not the chime.
Old Aug 23, 2010 | 05:25 PM
morpheous's Avatar
yeah,i came across that code also,disabled the light but the seat belt chime,still sounds off.
abcxyzzz
Dec 2, 2011 05:47 PM
muddipaws
Jun 30, 2011 04:14 PM
immusicman
Nov 2, 2010 08:39 PM
bigsnowdog
B7 Models
9
Jul 15, 2008 12:53 PM
boges55
May 16, 2007 06:44 PM
