Shifter surrounding plastic
Old Jul 6, 2012 | 12:19 AM
Sheasta's Avatar
Default Shifter surrounding plastic
Was already peeling and then some goo gone fell on it (long story). So it looked like this: Name:  41dcbb7f.jpg
Size:  106.2 KB it melted the ****. I sanded it with medium coarse sand paper. Now it looks like this : Name:  d17d73fb.jpg
Size:  117.0 KB still needs fine sanding and then paint or I can just buy another piece. Part number : 8D0 864 261H . Suggestions? Thoughts?
Old Jul 6, 2012 | 10:19 AM
brrman's Avatar
Keep at it. Just don't use regular paint - get paint made for vinyl (at pepboys, autozone, etc)
I did mine about 6 years ago and it still looks like this...
Old Jul 6, 2012 | 11:22 AM
Sheasta's Avatar
Looks good. So black vinyl paint? Did you sand it after paint? How many coats?
Old Jul 6, 2012 | 12:20 PM
morpheous's Avatar
Mine looks like this after a re haul. I even sanded down the silver shifter housing even more,since this picture was taken,it looks even better. ^_^
Old Jul 6, 2012 | 12:38 PM
morpheous's Avatar
Where did you purchase that shifter ****? and for how much?
Old Jul 6, 2012 | 01:35 PM
vgo's Avatar
vgo
^^ those are the blue orb ***** (theres an LED around the shere). To shift into drive you pull up. Pretty neat.
Shaesta just go on and paint it or wrap fabric. Which ever. Its cheaper and you did it yourself.
Old Jul 6, 2012 | 02:36 PM
brrman's Avatar
UHH wrong. The **** is a MOMO three piece - the ring you see is a gray leather insert, not some led light (eww). I bought it off a a guy years ago. I'm pretty sure they don't make that model anymore.
You do pull up on the **** to shift because I installed the SPP tip mod.
I did sand the shift plate after painting - between the 2 coats. And you'll notice I also sanded my actual shift plate to give it a brushed look.
Old Jul 6, 2012 | 04:30 PM
vgo's Avatar
vgo
My bad! Either way it does look nice though
Old Jul 6, 2012 | 05:59 PM
TaConklin's Avatar
If you have any auto paint shops around you look for stuff called SEM colors. It's made specifically for interior surfaces. Can even be used on seats, leather, etc.
Old Jul 6, 2012 | 08:56 PM
Sheasta's Avatar
Alright I will try to paint it soon. I'll finish smoothing it out first. What grit do you recommend after paint?
