Shut car off was working fine filled it up and now!!!
I have had my a4 for about 2 1/2 months now with a few issues and now I drove to work no problems drove home no problems drove to the gas station no problems....
I shut the car off and left the radio on and filled it up and started the car and realized my tachometer and speedometer both suddenly stopped working my tach does a little micro flutter though... Check engine light is on but last I checked it was for an o2 sensor
I pulled the codes again... All it said was o2 sensor! I realized if I turn the key on and off until my tach needle lifts up, just a little then start the car it all works fine more info on my car.
1996 a4 quattro
2.8 5 speed manual
1996 a4 quattro
2.8 5 speed manual
Have not had a chance to try the ignition switch yet but I noticed this morning that I hear a repeated clicking sound from my dash almost like a relay that is clicking on and off even after I shut the key off and pull the key out
I wanted to post on this topic because it sounds like you're experiencing exactly what happened to me. To start with it sounds like a loud ticking or clicking coming from behind the dash this would be the RELAYS. I went through all of these and found 2 bad ones that stopped the clicking and dash issues. After that my cluster went bad but that was totally unrelated haha but you might want to look into those relays behind the instrument cluster area as those commonly go bad too if you got higher milage. Hope that helps you out a little bit!
smorbukk
Nov 22, 2012 09:27 AM
dha514
Apr 19, 2008 04:54 PM
