Slave cylinder line
Old May 11, 2010 | 09:35 AM
shady927's Avatar
Default Slave cylinder line
as most you probably know I am converting my 6 speed s4 to 5 speed. Anyways I have a trans from a 97 a4 trans in completely fine shifts perfect. However as some of you know they only used the slave cylinders of that trans for 2 years 96-97. So the lines I have for my 6 speed are pressed in and held with a clip, this one is threaded in. With that being said I need to find the line for that slave cylinder. I tried looking into buying a new slave but that doesnt come with the line. ANd also u cannot swap the s4 and a4 slaves. The s4 is bigger and will not fit.
Old May 11, 2010 | 09:39 AM
dragonrage's Avatar
Doubtful.
I am converting my 6 speed s4 to 5 speed. .
You're going to kill that transmission very quickly.
Old May 11, 2010 | 03:01 PM
Mike-2ptzero's Avatar
Seems odd since I use B6 S4 slave cylinders in my A4 and other A4's.
You should have bought a 2000+ A4 transmission, they seem to be a little stronger then the older ones.
Old May 11, 2010 | 03:03 PM
Wow where is the delete button?
Old May 11, 2010 | 07:50 PM
joenelson7687's Avatar
Mike...just watched your video and i have one thing to say: Jizzed in my pants
Old May 11, 2010 | 08:35 PM
dragonrage's Avatar
It's perfectly normal, nothing wrong with me. Oh, and we're going to need a cleanup on isle three.
Old May 14, 2010 | 03:58 PM
shady927's Avatar
u have a 2000 a4 I said a 96-97 trans uses different slaves after 97 they switched to the ones that u r using. Plus I saved myself money getting a 5speed being I only paid 250 so for the time being it will be fine. Just need to find that line, will probably end up making one.
Old May 14, 2010 | 08:18 PM
jiggleo's Avatar
yep most likely
proctorb18
Jul 26, 2013 11:07 PM
Pappa Phil
Mar 21, 2009 11:22 PM
GFBrummer
Aug 20, 2007 06:50 PM
kooldaddy
Jun 15, 2007 06:52 PM
ThePapaCMan
Jun 11, 2007 09:36 AM
