smoke! all colors.
Old Apr 13, 2008 | 11:23 PM
  #31
CAB509's Avatar
6th Gear
Default RE: smoke! all colors.
the piping is leading into the Turbo I think (it's from a jetta, so it's a transversally mounted engine) You would throw a code, I don't have coil packs on My car, so I'm not sure if there are any tell tale signs when you look at them, and BERU is not a German word I am familiar with, but many parts have some German on them because they are in fact from Germany.
Personally if I were you, I would just replace them all
pick of S4 coilpacks
Old Apr 13, 2008 | 11:29 PM
  #32
A4speed's Avatar
ORIGINAL: omidsaudi
hey a4speed have you ran your quarter?
and what is a heatshield?
evoheatshield is a phenolic spacer between the manifold and the head. it absorbs heat allowing the air to be colder going into your engine, thus making more hp. it also creates a barrier so that heat from the head won't go into the manifold, so you have colder IAT temps.
i have ran a quarter mile before, but only with about half my mods.
Old Apr 13, 2008 | 11:30 PM
  #33
omidsaudi's Avatar
how much do coilpacks go for?
i have the same ones from those
Old Apr 13, 2008 | 11:33 PM
  #34
NeedanA4B5's Avatar
Member
Could be intake manifold gasket too. First you need to do a compression check on all 4. that will tell you if its rings/headgasket. if all are within spec. then its something else like intake manifold or turbo seals etc. O btw when your cars not acting right dont beet the **** out of it. And when it first started misfiring you shoulda checked it.
Old Apr 13, 2008 | 11:35 PM
  #35
A4speed's Avatar
omidsaudi: do you have a boost/vacuum gauge?
Old Apr 13, 2008 | 11:36 PM
  #36
omidsaudi's Avatar
yea i know.
i shouldnt have pushed it that hard when i already knew it was choking.
so i should do a compression check first?
Old Apr 13, 2008 | 11:37 PM
  #37
omidsaudi's Avatar
no, my birthday just passed by and my friends got me it and its coming in the mail right now. its a greddy profec spec2
should be coming in within the next couple days.
Old Apr 14, 2008 | 05:25 PM
  #38
A4speed's Avatar
that sounds like a boost controller, does it read the vacuum and boost produced?
when u install a boost gauge, if the vacuum gauge goes back and forth at idle, you def. have a leaking head gasket.
Old Apr 14, 2008 | 11:20 PM
  #39
ghost6303's Avatar
ORIGINAL: omidsaudi
my check engine light has been on for the last couple of months but it was running fine so i didnt think anything of it.
it began to flash as i was bogging out.
ah famous last words...
Old Apr 14, 2008 | 11:23 PM
  #40
CAB509's Avatar
6th Gear
my CEL is on but I know exactly what is throwing it, and nothing is that important, except for maybe the thermostat, but that'll get fixed soon hopefully.
