Sputtering above 3200rpm: A4 B5
Old Aug 3, 2018 | 07:13 PM
chicotico's Avatar
Default Sputtering above 3200rpm: A4 B5
My A4 Avant 1.6 (ARM engine, 101HP), 07/2000 has stable idle, but sputters above 3200rpm (any gear) and its gas mileage has become terrible.
VCDS yields 1 code:
00520 - Air Mass / Air Flow Sensor (G70)/(G19)
28-00 - Short to Plus
I've cleared the code, but it immediately comes back.
Is it simply a matter of replacing the MAF?
From what I've read in other threads of people experiencing similar sputtering behaviour, most likely candidates would be
-spark plugs and/or cable(s)
-coils
-fuel supply
-camshaft position sensor
But the error code doesn't seem to support any of these, does it?
cheers
Old Aug 7, 2018 | 01:52 AM
george1546's Avatar
A dirty of bad air flow most certainly can have those symptoms if not be the most common one. You car throwing an air flow error is also a good sign in where to start looking, give your air flow a good clean and see if it helps otherwise see if you can find a replacement and go from there.
Gypsy Man
Jul 23, 2011 02:51 PM
b5audi1.8t
May 28, 2009 07:11 AM
Trey25
Aug 27, 2007 12:21 AM
AudiTurbo
Sep 23, 2006 01:52 AM
myaudi98
Jul 5, 2006 12:11 AM
