Started tuning for e85 :)
Well, that's all it is right now, a plan. Next month I head back to Iraq and start making a little extra money. I'll start ordering parts and stockpiling them for when I get back, then take the car off the road for a week or two and just install everything. Once it's done, I'll unleash the beast on the world! (Of course, only after a good break in period).
I plan on getting a lot of maintenance stuff done while I'm at it. The basics, TB, CAs, CVs and stuff like that.
Thanks for the encouragement, I'll be sure to keep things posted as I buy, then eventually install things...
Just have to be carefull with E85 because the knock sensors dont work correctly when running it and this means the ecu can not adjust for too much timing.
Another A4 owner in CO found that out the hard way by pushing the timing too far and blowing the motor. He was running a GIAC tune for E85 and then kept adding more timing till it let go.
E85 does make more power then standard pump gas and cost less money then running unleaded race gas, but mainly it burns cleaner which is why it is produced.
For racing or making big power the fuel to use is Q16 which is 117 octane. Best fuels to use are the ones with the smallest difference between RON and MON.
And Yes I agree that the race fuel is the way to go for sure, but your draging yours on the track and I drive mine on the road. Plus it is very expensive. I wish I can q16 everyday. that would be awsome!
I'm going to be putting sick numbers down.
You're in Colorado, Mike's in Cali. When you're done, I wish I could see the two of you at a couple trips down the strip... What a sight that would be! Two B5s stroked over to 2.0 pushing crazy boost tearing down the drag strip...
If it EVER happens, you guys better post some videos up here!!!
