Starting problem after fill up
Old Feb 14, 2008 | 06:38 PM
BraMas's Avatar
Default Starting problem after fill up
After the last 2 fuel stops the car has not wanted to start. It will crank and crank and than finaly start and run like crap for a minute. It only has done this setting at the gas pump after a fill up never any other time. Fuel Pump issue?
Old Feb 14, 2008 | 08:27 PM
ImTheDevil's Avatar
Default RE: Starting problem after fill up
Hard to say but I've seen this posted a few times. I'm not sure if anyone has diagnosed the reason, but searching for this may yield some more info. It's been discussed but I don't know if there was ever a solution.
Old Feb 14, 2008 | 10:02 PM
chaos92287's Avatar
yeah, i had that problem but it has since gone away. its most likely the fuel pump, and you should change the filter as well while your down there.
Old Feb 15, 2008 | 05:49 AM
david9999's Avatar
This is a problem with the fuel vapor recirculation circuit.
Two possibilities cause this.
Take off the plastic cover that sits on top of the air filter box.
Behind the box is a set of hoses and some grey and black one way check vavles,
Check that the valve has had a hole rubbed in it by the metal clip that sits right in front of it.
The usual cause is the black electrical valve that sits right behind the air filter box. It will have several hoses and an electrical connection. The valve often gets clogged with charcoal particles from the vapor collection canister. Replacing the valve is a 10 minute DIY and the part, as I recall is about 50 dollars.
Guaranteed to fix the problem. Fixed the problem on my car, and on several other members over the year.
Old Feb 15, 2008 | 12:21 PM
chaos92287's Avatar
^ where were you when I was having this problem lol
Old Feb 15, 2008 | 12:43 PM
techbod's Avatar
Servicing components of activated charcoal filter system - front-wheel drive and four-wheel drive[/align]Servicing components of activated charcoal filter system - front-wheel drive and four-wheel drive[/align]Note:
Arrow in illustration points in direction of travel
Vent pipe
Activated charcoal filter
â—†Location: behind wheel housing liner, front right
â—†To remove, remove wheel housing liner, front right [/ul][/ul]
Breather pipe
â—†Open to atmosphere; comes out at vehicle floor, right side [/ul]
10 Nm
Activated charcoal filter solenoid valve 1 -N80
â—†Checking operation and activation: [/ul][/ul]
To intake manifold [/ul]
evap system
[IMG]local://upfiles/12092/190554A0723241FD84A0C1DEFBA81B58.jpg[/IMG]
Old Feb 15, 2008 | 10:19 PM
BraMas's Avatar
thanks I will try what was stated above. I did try the search but nothing came back[:@]
Lees
Sep 27, 2013 01:51 PM
turbo.quattro
Aug 5, 2008 10:21 AM
david9999
Mar 17, 2007 01:16 PM
david9999
Jun 5, 2006 03:34 PM
por1984
Jan 9, 2005 07:33 PM
