Starting issue after fill up.
Old Jun 8, 2008 | 02:07 AM
turbo.quattro's Avatar
Default Starting issue after fill up.
I bought my first Audi last week. Its a 99 1.8T Quattro. I bought it in very good shape. The previous owner how ever told me that when i go to fill up with gas, the car will take about 4-5 cranks for it to start and a bit of some gas, then when it does give it a little gas again and hold the rpm at about 1500. I asked him why is this? and how can i fix it? He said a new Gas cap. (because he had some cheap one on it) So i went out too an auto wrecker and took one Gas cap off another B5 Audi. Fit right, and clicked. Now as i went to fill up with gas tonight, it still did it. I filled up about 3/4 a tank, and had to crank it 4-5 times till it started, then rev it a bit till about 1500rpm, and hold for a few seconds. AND this only happens after i fill up, the car always starts fine after this. Car has no problems other then this. Runs strong.
I heard someone tell me it may be i need a new "Evap canister purge valve"
Anyone help me out please!
Thanks-
Old Jun 8, 2008 | 03:08 PM
tHe kNiGHt FaLL's Avatar
Default RE: Starting issue after fill up.
its very possible... for the purge valve... if its stuck closed.
you can buy one and change it yourself its very easy....
Old Jun 8, 2008 | 03:17 PM
Yea i think i may look around and get one. I was just talking to another VW/Audi mechanic about this.. he said the same.
Old Aug 4, 2008 | 11:34 PM
mrdb85's Avatar
i am having the same issue, although the refueling problem went away after i changed my MAF. however is the purge valve the thing you can hear ticking, because i dont hear it anymore and i think that is the other problem i am having, my engine light is still on and my car idles differently since this started. thinks its my evap valve??
Old Aug 5, 2008 | 10:21 AM
CRAZYHAWK's Avatar
Do you have any codes?
Lees
Sep 27, 2013 01:51 PM
Grad0701
Aug 24, 2013 12:26 AM
BraMas
Feb 15, 2008 10:19 PM
david9999
Mar 17, 2007 01:16 PM
david9999
Jun 5, 2006 03:34 PM
