Starts on second key cycle-Bad Starter?
Old Feb 11, 2014 | 09:51 PM
99Quatt6's Avatar
Default Starts on second key cycle-Bad Starter?
Hey Guys-
I have a '99 A4 qm 2.8l and lately I've noticed that every once and a while, when I turn the key to crank, there is no crank, but rather the soft sound of the starter spinning and not engaging. I key off and back up, and she starts right up. Now the other day I just hear spinning and she won't start at all. I'm leaning toward a starter solenoid and the bendix sticking, but I'm curious if anyone else has had similar issues.
Thanks in advance!
Old Feb 11, 2014 | 09:56 PM
OldAudiA4B5's Avatar
it's probably not your problem but I had an issue of it starting on every 2nd try. On the first time, it would fire up and burble out after a second. Turned out to be the key. If I used the spare copied key, it would always start on the 2nd attempt. If I used the factory key, it would start first go.
Old Feb 12, 2014 | 09:22 AM
smittylube's Avatar
If your hearing the starter spinning and not the motor your right on target, but the ring hear could be loosing teeth so verify that when you change it.
Old Feb 12, 2014 | 09:58 AM
mtroxel's Avatar
What he said^^^^
traviskinslow
B7 Models
Dec 15, 2014 11:54 AM
tumble220
May 18, 2011 10:00 AM
a4sport
Sep 25, 2006 04:08 AM
OysterBay
Nov 6, 2005 06:50 PM
