Stereo not receiving power until turbo timer starts
Old Jun 11, 2013 | 10:02 PM
HulkB5's Avatar
Default Stereo not receiving power until turbo timer starts
My piooner in dash dvd player has recently stopped working, and will only work when my turbo timer is counting down despite the orientation of the key or if the key is even in the ignition. There is no obvious signs of why it is doing this to me. I was wondering if anyone has any suggestions.
Here is the manual for my turbo timer
http://www.greddy.com/upload/file/FATT.pdf
Here is a video.
I recently changed out my Ignition Switch and pulled some relays to test them.
and i changed out the starter.
Old Jun 11, 2013 | 10:37 PM
Pbcrazy's Avatar
What wire/fuse did you tap into for the timer?
Old Jun 11, 2013 | 10:55 PM
HulkB5's Avatar
It's attached to that middle nut
Attached Thumbnails Stereo not receiving power until turbo timer starts-image.jpg
Old Jun 12, 2013 | 01:22 AM
HulkB5's Avatar
Fixed the problem, What happened was that the ignition switch wasn't fully seated into the slot by about an eighth of a inch. I was able to wiggle it in tighter to where it seated all the way into its collar.
Once i tested to make sure, turns out it wasn't triggering that little pin in there.
cmacelo121
Oct 30, 2009 07:59 PM
theguy1084
Jul 8, 2007 11:56 AM
poloblue22
Jun 11, 2005 02:40 AM
poloblue22
Jun 10, 2005 11:32 PM
fritz
Nov 22, 2004 01:15 AM
