Struts make noise when driving slow. ANNOYING
Old May 16, 2009 | 06:23 PM
Emilgevor's Avatar
Default Struts make noise when driving slow. ANNOYING
hey guys so recently all my 4 struts started to squeak when its warm or hot out and when its cold its quiet. Just wondering how could i fix that. Could i spray something or what to stop that annoying sound
Old May 16, 2009 | 07:59 PM
Interceptor's Avatar
Your sure it's from all 4 sides? Not just one side sounding badly? I would also look at the control arm bushings and you use some WD40. My rear passenger side is making a nice creak sound slow over bumps but I can't tell yet if it's my shock or a bushing.
Old May 17, 2009 | 11:50 AM
Emilgevor's Avatar
it could be control arms also yeah mechanic told me that i might need new once soon yeah i guess ill get some WD40 and see what i can do about it
Old May 17, 2009 | 04:44 PM
CCA4's Avatar
Yeah i think its more likely control arm(s) than your shocks. I've replaced several of mine and the squeak goes away every time. The WD40 will help a little, but you're eventually gonna have to replace some-or more likely all-of them soon. Another thing you might try is to get a grease gun with a needle on the end, not the grease fitting, but the little needle. And pump the bushings full of grease. They aren't designed for that, which is why there's no grease fittings, but it'll help the squeak so it doesn't drive you nuts while you're waiting to replace them
warrenh
B8 Models
Jun 8, 2012 03:02 PM
jhsoccerodp
Feb 7, 2009 11:46 AM
icebox425
Aug 30, 2008 11:17 AM
dhourihane
Jun 8, 2006 02:53 AM
InsaneHatter
May 27, 2005 10:38 PM
