Subs + amp install
Old Jul 24, 2008 | 12:52 PM
lawnferie's Avatar
Default Subs + amp install
I'm planning on putting some in my 99.5 1.8T (non bose). I have the Concert audio headunit. Can this be done with stock headunit????
Want to make sure before I try to install and then have to stop half way...
If it doesn't work (hopefully it will but...) any suggestions on replacing?
Old Jul 24, 2008 | 01:02 PM
fred2ka4's Avatar
Default RE: Subs + amp install
You can do this one of two ways. You can either tap into the rear speaker leads and hook up a low level adaptor which will give you a set of rca outputs for you bass amp or you can buy an amp that has high level inputs. Either way you will have to tap into the speaKer leads. You are also going to have to find out which wire off of your harness is the turn on lead for your amp. I have a factory Bose headunit with a JL Audi 6 channel amp running MB Quarts and a JL Audio Stealth box designed for the Audi. It works and sound great and mine was an easy install since the Bose amp was in the rear of the car, the connections were easy.
I went to Audi World and there was a pin wiring diagram for the Bose system and that helped a lot. I don't know if there is one for the non Bose system but it can be done.
Old Jul 24, 2008 | 06:19 PM
rhyab1's Avatar
Get an entire system,deck first, door speakers, subs amps, dont half **** it
Old Jul 24, 2008 | 07:19 PM
lawnferie's Avatar
ORIGINAL: rhyab1
lol. if i only had the $$$. remember that I'm getting this setup at $250...
I'm on a 17-year-old budget....[8D]
Old Jul 25, 2008 | 02:04 AM
Dallas09's Avatar
Im also on a 17-year old budget and i wanted to give you more help but the ******* forum is still messed up, anyway i left everything stock and added a sub, it sounds great.
Old Jul 25, 2008 | 02:07 AM
Dallas09's Avatar
You dont actually need an adapter i dont think, you can tap low level before the amp, its in a writeup just search google, otherwise u can use high level like i did.
Old Jul 25, 2008 | 11:40 AM
rhyab1's Avatar
Whats up with site/ Can only post 1 sentance it seems....
Old Jul 25, 2008 | 05:56 PM
lawnferie's Avatar
i think theyre fixing it so just hang in there... i know its a PITA
vbman11
Sep 7, 2011 11:39 PM
theTTkid
Mar 20, 2008 10:04 PM
Leifer
Nov 17, 2007 06:11 PM
lazyjayz
Jul 9, 2007 01:00 AM
betz470
Jun 23, 2005 10:39 PM
