Swapping S4 seats into A4 1.8t
I think most, if not all S4s, had power seats. If you're going swap in power seats, you're going to have to have the mounts welded down properly (extra plate to distribute the stress from the mounting points) so it shouldn't really matter what car you get the seats from. They'll have to be welded down anyways.
the mounts to the body are different. The power uses two rail on each side of the seat and the manual has one rail right in the middle. To mount power in a manual your going to have to cut the manual mount that sticks up off the car. Then your going to have to weld a nut in the floor to thred a bolt into.
not positive but i think as long as you have power lumbar the s4 seat harness plugs into the a4 harness for delivering power. there are three (possible, if heated )connections on the s4 seat. the power will hook up to the power on your a4 if you have power lumbar, the airbag hooks right up, and the heated seat plugs right up to the stock a4 plugs. if you dont have power lumbar and/or heated seats, youll need to wire that up if you want the function. if you dont have power lumbar youll have to bring power in in order to adjust the seat. as for welding the nut down, whats wrong with just tightening it under the floor?
pzp107
Nov 8, 2020 11:28 AM
