Swapping S4 seats into A4 1.8t
Old Sep 28, 2012 | 04:41 AM
T-Wall's Avatar
Originally Posted by Skythe
I think most, if not all S4s, had power seats. If you're going swap in power seats, you're going to have to have the mounts welded down properly (extra plate to distribute the stress from the mounting points) so it shouldn't really matter what car you get the seats from. They'll have to be welded down anyways.
Alright, thanks for the info. By mounts do you mean where the seat attaches to the body of the car, or where the motor for the power seat is placed? When I swapped out seats in one of my previous cars, they were just bolted to the floor. Is there extra wiring needed for the power seat motor also?
Old Sep 28, 2012 | 07:44 AM
jonbonesjones's Avatar
Moderator
the mounts to the body are different. The power uses two rail on each side of the seat and the manual has one rail right in the middle. To mount power in a manual your going to have to cut the manual mount that sticks up off the car. Then your going to have to weld a nut in the floor to thred a bolt into.
Old Sep 28, 2012 | 09:51 AM
redline380's Avatar
Legal Moderator
not positive but i think as long as you have power lumbar the s4 seat harness plugs into the a4 harness for delivering power. there are three (possible, if heated )connections on the s4 seat. the power will hook up to the power on your a4 if you have power lumbar, the airbag hooks right up, and the heated seat plugs right up to the stock a4 plugs. if you dont have power lumbar and/or heated seats, youll need to wire that up if you want the function. if you dont have power lumbar youll have to bring power in in order to adjust the seat. as for welding the nut down, whats wrong with just tightening it under the floor?
Old Sep 28, 2012 | 10:33 AM
Moderator
you mean just bolt thraight through the chassis? Thats possible I bet theres many ways to do it, i think taking a nut would be easiest .
pzp107
Nov 8, 2020 11:28 AM
vtraudt
Aug 19, 2012 08:37 AM
Iniquite
Dec 2, 2010 12:46 PM
darksi3842
Feb 21, 2005 04:17 AM
david9999
Feb 20, 2005 09:09 AM
