Temp gauage
Old Aug 13, 2009 | 08:12 AM
cacumm02's Avatar
Default Temp gauage
My temp gauge on my 98 2.8L works only when it wants too. Is this most likely a problem with the temp sensor or somethig else?
Old Aug 13, 2009 | 09:24 AM
ImTheDevil's Avatar
Temp sensor - well known issue on these cars. $20-25 and less than an hour to change using a ratchet and a screwdriver. Make sure you order a new retaining clip for it - it's plastic and probably brittle from heat.
Old Aug 21, 2009 | 05:51 PM
cmacelo121's Avatar
do you have any picture or any idea where's the temp sensor in an 1999 audi a4 1.8t? mine is not working too...
Old Aug 21, 2009 | 08:23 PM
Lotus49b's Avatar
hey... i JUST did mine.. .. if you are talking about the cooling temp sending unit.. they are 7.99 at autozone..
here is the website i read to change mine..
http://www.a4mods.com/index.php?page...ECTsensor.html
pry this clip off with a flathead.. make sure you dont drop it
warning!@!!!!! MAKE SURE YOUR CAR IS COLD WHEN YOU DO THIS.. THIS IS WHAT HAPPENED WHEN I DID IT WHEN IT WAS HOT..
http://viewmorepics.myspace.com/inde...628&i=61411245
Old Aug 21, 2009 | 08:59 PM
cmacelo121's Avatar
ok thanks ill take a look at it if thats the problem..
Old Aug 27, 2009 | 08:22 PM
cmacelo121's Avatar
theres a two sensor in there a blue one and a green one right beside the coolant tank, which one would be the coolant sensor??
redline380
Jan 13, 2012 01:10 PM
zer0vette
Jul 21, 2010 10:30 PM
kbrookst
Oct 24, 2009 06:37 PM
A6_TUNER
Sep 22, 2008 11:38 PM
Agro
Jul 10, 2006 08:19 PM
