Temp gauage
Temp sensor - well known issue on these cars. $20-25 and less than an hour to change using a ratchet and a screwdriver. Make sure you order a new retaining clip for it - it's plastic and probably brittle from heat.
hey... i JUST did mine.. .. if you are talking about the cooling temp sending unit.. they are 7.99 at autozone..
here is the website i read to change mine..
http://www.a4mods.com/index.php?page...ECTsensor.html
pry this clip off with a flathead.. make sure you dont drop it
warning!@!!!!! MAKE SURE YOUR CAR IS COLD WHEN YOU DO THIS.. THIS IS WHAT HAPPENED WHEN I DID IT WHEN IT WAS HOT..
http://viewmorepics.myspace.com/inde...628&i=61411245
zer0vette
Jul 21, 2010 10:30 PM
