Is there any way to disable the ABS light? I dont really care about ABS.
Old Aug 27, 2010 | 02:22 PM
  #21
alexmurphy's Avatar
Originally Posted by CrazyPete
My ABS light is solid but the brake light is only blinking. What does that imply? I do not have 2 solid lights.
that means the ABS is on its last legs. basically if you don't replace the module soon it will stop working altogether. if you live somewhere it doesn't rain or snow often, you could just leave it. but anywhere else, I would recommend replacing the module
Old Aug 27, 2010 | 02:52 PM
  #22
CrazyPete's Avatar
Member
Is the behavior of the lights consistent across all models or is it individual based on which specimen I have. My abs module is off the car completely and sent off for a rebuild but the brake light is only blinking.
Does the blinking brake light then imply a worn brake pad sensor?
Old Aug 27, 2010 | 04:13 PM
  #23
alexmurphy's Avatar
wait what now, you took off the ABS module completely, and your wondering why the car is giving you blinking lights?
Old Aug 29, 2010 | 06:43 AM
  #24
CrazyPete's Avatar
Member
No, thats obvious. I was more wondering what it takes to get a solid brake light. Solid ABS light is obvious but I was wondering if the blinking brake light is a further problem that needs to be addressed separately.
Old Aug 29, 2010 | 01:06 PM
  #25
Dallas09's Avatar
Dont worry about the brake light, that comes on under certain ABS faults, the module not working or having communication problems for example, the abs AND a flashing brake light will come on. Most wheel sensor faults will only turn on the ABS light.
Old Aug 29, 2010 | 05:04 PM
  #26
CrazyPete's Avatar
Member
Ok, thanks Guys =)
I await my rebuilt module then to resolve the blinking lights. Seems as if my silicone trick worked on the back brake. It's now releasing and engaging properly and I didnt have to tear it down at all.
Old Sep 2, 2010 | 06:19 PM
  #27
CrazyPete's Avatar
Member
Success!!
I swapped out the ABS module and to my surprise....it worked!
All the warning lights went out. I'm a happy camper.
pacino13211
Oct 10, 2013 07:46 PM
Amazo
Mar 30, 2013 06:30 PM
porschephd
Oct 11, 2011 12:19 PM
a4autocrossr
May 31, 2005 01:00 PM
