Timing belt not wanting to line up.
Old Dec 10, 2011 | 02:34 AM
HulkB5's Avatar
Default Timing belt not wanting to line up.
So i just spent 4 hours trying to get my timing belt perfectly on, and turns out it refuses to match up.
I tried switching a tooth over and then is was to far, and when i got it to as close as i possibly could it still manages to be off.
During these pictures the crankshaft is set to exactly TDC.
Heres a picture of the cam gear lining up with the valve cover,
Heres the intake cam
Heres the exhaust cam
Old Dec 10, 2011 | 09:01 AM
ImTheDevil's Avatar
You're fine like that. It won't always line up 100% but you'll run perfectly fine.
Old Dec 10, 2011 | 12:58 PM
HulkB5's Avatar
Thank god.
Thanks Imthedevil.
I figured that, but its always nice to hear another opinion.
Old Dec 10, 2011 | 01:48 PM
ImTheDevil's Avatar
Yup, no problem. It's always nerve-wracking when it comes to critical servicing. If you wanted to set it up absolutely dead-on, this is where you'd use a cam-locking tool with the crank attachment - you could lock things into place, loosen the center cam sprocket bolt, and rotate the sprocket until it lined up perfectly, then torque it back down. It's not necessary though, so don't sweat it.
Old Dec 10, 2011 | 06:07 PM
TaConklin's Avatar
I'll log this information for later.
Old Dec 10, 2011 | 09:33 PM
turbo kraut's Avatar
Tech Guru
there is a thread just like this on az.... people worry about this **** way too much
lol j/k
but yeah that is perfect
Old Dec 10, 2011 | 10:28 PM
redline380's Avatar
Legal Moderator
are you sure? pretty sure the exhaust would be on the left side and the intake on the right side. sorry just had to point that out but timing looks pretty decent to me
Old Dec 11, 2011 | 04:35 AM
HulkB5's Avatar
Hahaha, Yes you are correct.
That's what happens when you put the img links in before you type what you want to say.
nigedvd
May 8, 2012 05:34 PM
coloradoaudigirl
Jun 19, 2008 10:35 PM
MeanAudiA6
Apr 13, 2008 11:26 PM
pyropenguin
Jun 10, 2006 10:25 PM
mikepangko
Apr 9, 2006 02:17 PM
