Timing crank cam sensor correlation VCDS block 93 negative value
Old Aug 15, 2018 | 02:13 PM
vtraudt's Avatar
Default Timing crank cam sensor correlation VCDS block 93 negative value
If block 93 (phase or cam/crank correlation or simiar) shows negative values, could that mean that cam chain link count (the famous "16")
a) too long
b) too short
Ditto on the timing belt:
c) more teeth (clockwise) between cam pulley and crank sprocket
d) less teeth
Again: negative "degree KW" in VCDS
Old Sep 11, 2018 | 02:11 PM
JETSPEED333's Avatar
SoCal Crew Member
I believe it can fluctuate between +/- 5. So you may be ok.
if the readings should be similar to the 2.0t here a vid that was helpful to me.
Old Sep 12, 2018 | 08:31 AM
vtraudt's Avatar
Yes, it fluctuates.
The question is: what does negative (vs. positive) values MEAN. I.e. is intake cam too far advanced (too far clockwise) and ECU takes out (negative value)? Or is is intake to far behind (too far counter clockwise)?
That then determines the corrective action (for example add a tooth of timing belt length between crank sprocket and exhaust cam pulley to move intake came a bit more forward (clockwise).
vtraudt
Jul 31, 2018 08:17 AM
rkelsey10554
Oct 19, 2013 10:43 AM
lukedorris
Sep 29, 2013 02:11 PM
bofett
Feb 23, 2013 07:29 AM
reaper
Oct 31, 2010 09:15 PM
