Timing via pistons?
Old Jan 3, 2011 | 09:59 PM
DOC_DEPALMA's Avatar
Default Timing via pistons?
Which piston needs to be where we i put my heads back on? Kinda stupid question I know but better safe than sorry
Old Jan 3, 2011 | 10:23 PM
ImTheDevil's Avatar
Cylinder 3 (rear passenger side) should be at top dead center. You can look at the tick mark on the crank pulley to verify this. On the heads, you need the cams positioned so that cylinder 3 is on the compression stroke (all valves closed). Reinstall the cam sprockets if they're off (shouldn't be) and rotate them so that the oval brackets on the front of the sprockets are horizontal with the larger of the two holes toward the center of the engine. Reassemble it that way, verify the timing once assembled (there are marks on the cam sprockets), and put the timing belt on. Reverify all the marks again after the belt assembly is done, turn the engine two full revolutions via the crank and a breaker bar. Listen for any piston/valve interference and as long as there is none, you're good to complete the rebuild.
Old Jan 3, 2011 | 10:46 PM
You are the ******* man.
Old Jan 4, 2011 | 05:53 AM
ImTheDevil's Avatar
Glad it helped Thats one nice thing about these cars - with the brackets on the cams, it's a no-brainer to set up the timing.
Fernandus
Jul 29, 2010 02:27 PM
q8_tt
Jul 3, 2010 09:17 AM
evilkowz
Oct 17, 2009 03:03 AM
euro4lfe
Mar 7, 2007 01:20 AM
fast_rides88
Aug 14, 2006 11:22 PM
