Tranny Help Please!!!
Old May 13, 2009 | 08:36 PM
knyks342's Avatar
Default Tranny Help Please!!!
Ok so i own a 99 a4 quattro 2.8l 5 speed
Yesterday I was driving and i was turning a corner I went from neutral to 2nd and nothing happened.
It went into gear but did not engage. I tried all gears including reverse and nothing.
So i took the car to my friend and he thinks it is the tranny.
My question to you is do i need a specific type of tranny since it is a quattro?
Where can i get a tranny? I was looking on ebay and saw some with code DVZ would that work?
Any suggestions would be amazing as I am really nervous as to how much money i am going to spend.
Thanks
Old May 13, 2009 | 09:34 PM
ghost6303's Avatar
when you put it in gear, does the RPM needle AND speedometer needle move?
Old May 13, 2009 | 10:26 PM
knyks342's Avatar
yes it does move...does that mean its something else?
Old May 13, 2009 | 10:27 PM
knyks342's Avatar
oh wait...i need to check...i am unsure, i will check it tomorrow....but for curiousity sake...what will that tell me?
Old May 13, 2009 | 10:35 PM
swinburn15's Avatar
if you look in your trunk where your spare tire is, there is a sticker and it tells you the transmission code. you will need to get the same code
Old May 13, 2009 | 10:37 PM
hiwords's Avatar
check your axles. the symptoms you described sound like an axle came out.
Old May 13, 2009 | 10:42 PM
ghost6303's Avatar
yea, if the speedometer moves but the car doesnt go anywhere one of your half shafts probably fell off. if the speedo doesnt move then your clutch probably went.
its a 5 speed i dont know why you would ever have to replace the entire thing unless you destroyed a gear or broke the housing somehow. but any transmission with an 01A bellhousing will fit.
Nemick
Sep 11, 2012 05:33 PM
luxuryimports1
Jul 4, 2009 10:56 PM
thursdaysstrike
Jun 19, 2008 06:38 AM
brent07
Feb 5, 2006 06:14 PM
