Tranny swap?!?!?!
Old Jan 12, 2009 | 08:33 PM
fatpat210's Avatar
Question Tranny swap?!?!?!
i need a new tranny i destroyed mine in a snowstorm and just beating the f^ck out of the tiptronic so the car is just sitting in the driveway waiting to get fixed but im tired of the tiptronic. i was wondering how much a swap to a five speed might be and what i would need to get my hands onto and if anyones tried it to give me some advice. everyone says to just sell the car and get a 5speed but the car is very special to me and as sentimental value to me. so any help would be appreciated.
Old Jan 12, 2009 | 11:24 PM
ghost6303's Avatar
you would need a new engine, transmission/mounts, and drivetrain components. the easiest way to do it would be to get your hands on a donor car to steal parts from and so you can see how it comes off. that makes it easier for putting it back together on your car. you would also need the wiring harness and ecu to go with all that stuff.
if you have a junk yard near you and are doing the labor yourself, you my be able to justify this route over selling the car. this project could become more expensive then the cars value when all is said and done.
Old Jan 13, 2009 | 01:16 AM
SAudi's Avatar
from what i remember you will need the tranny, mounts, clutch and all that other good stuff, but you will also need a new crank or an engine that has the crank made for the manual tranny. personally not worth the swap.
Old Jan 13, 2009 | 08:24 AM
Siena's Avatar
I've done the conversion for my customers.
Never had to replace the crank - had custom SM LW flywheels made, with the doss designed to accept a spigot bearing.
Old Jan 13, 2009 | 04:27 PM
fatpat210's Avatar
how much did the whole job cost to do?
Old Jan 13, 2009 | 07:21 PM
Siena's Avatar
How much did it cost?
All depends on source of parts, I wrench for a living.
Old Jan 13, 2009 | 07:38 PM
onepoint8tee's Avatar
You sure you killed the trans? Usually when people are dicking around in the snow they just snap an axle.
Old Jan 13, 2009 | 11:07 PM
fatpat210's Avatar
yeah im pretty sure over a period of time my first gear wouldnt catch and then after probably 2 months it got worse and worse till the car wouldnt move unless you reved it up to 4000 for 5 seconds then the car i guess would go over to 2nd and start driving so when i was raping the poor virgin parking lot there was no 1st gear. i felt like a jolt or a it sounds weird but a crack and there was black fluid dots following me i thought it was oil from the engine but i check the levels and they were fine so i got to a friends house and the car wouldnt make it up the hill and then it wouldnt reverse we ended up pushing it about 1/2 a mile where i left it for 3 days. i think a seal broke but the first gear is what bothers me and if i need to rebuild the tranny id rather get what i originally wanted and thats a 5speed but if i cant do i guess ill have to part out the car and scrap it and start savin up for a 5speed or try and find a bmw e30. the other problem with the car is that it wont start like it will start once for 5 seconds and die after that theres no chance so idk its starting to seem not worth it to me its just makes me depressed
Old Jan 13, 2009 | 11:25 PM
SAudi's Avatar
not to be a dick but if oyu end up parting out the car, how much you want for th ekeys locks and keyless entry reciever.
Old Jan 13, 2009 | 11:29 PM
fatpat210's Avatar
Wink
hahaha no i would probably sell everything somewhat cheap and id have to figure out prices but i think maybe $40 bucks is pretty good im just putting it out there if i have enough to part out then my prices would be cheap as ****
J_PEZ
Jun 14, 2012 08:46 AM
JettaRedIII
Mar 11, 2009 08:50 AM
gmatov
Feb 20, 2009 10:45 PM
GraffixWB
Feb 16, 2006 05:08 PM
rowingdude
Aug 28, 2005 03:53 PM
