Tranny Swap
Old Apr 4, 2010 | 11:42 PM
KinkySlayer's Avatar
Default Tranny Swap
I have a '98 2.8 A4 Quattro, it's a 5 speed, and I was wondering if swapping the tranny out for a 6 speed S4 tranny would be feasible. If so, where would I be able to acquire said tranny?
Old Apr 4, 2010 | 11:45 PM
Andrew149's Avatar
yes it will work
Old Apr 4, 2010 | 11:49 PM
Would it have to be from a similar year? Or will it work with any S4 tranny?
Old Apr 5, 2010 | 03:39 AM
Andrew149's Avatar
any b5 year will work
Old Apr 5, 2010 | 12:03 PM
Alright, thanks
Old Apr 5, 2010 | 12:08 PM
chocalotstarfish's Avatar
Super Moderator
You need additional parts... You might be able to search and find it right now I'm looking for it but yeah it's not a straight bolt job.
Old Apr 5, 2010 | 12:19 PM
Super Moderator
From what i've found by searching for you
You will need all the following 6spd components:
Transmission
Driveshaft
Shifter and its linkages
(Maybe the driveaxles too, but I dont think so)
And rear diff + drive shaft The rear diff isnt necessary.BUT you wont have the EXACT gearing as a factory equipped 6spd car. But the 6th gear, regardless, will still drop the RPM's
There was a DIY but can't seem to locate at this time
Old Apr 5, 2010 | 12:33 PM
Super Moderator
F-ing found it! *insert proud face*
Old Apr 5, 2010 | 01:19 PM
Mike-2ptzero's Avatar
Since you own a 2.8 you shouldn't have a problem with the driverside transmission mount since the subframe on the 2.8 is like the S4 subframe which are different then the 1.8t subframe.
Old Apr 6, 2010 | 02:37 AM
Thankyou! lol. Very very helpful. Hopefully I'll be able to get this all done in not too long x.x;
J_PEZ
Jun 14, 2012 08:46 AM
JettaRedIII
Mar 11, 2009 08:50 AM
gmatov
Feb 20, 2009 10:45 PM
GraffixWB
Feb 16, 2006 05:08 PM
rowingdude
Aug 28, 2005 03:53 PM
