trubo only pushing 5psi
Old Jan 22, 2011 | 08:03 PM
Got_A4's Avatar
Default trubo only pushing 5psi
sup guys i felt my car a little sluggish and the top end, so i pulled the boost gauge off the race car and ghetto rigged it on the a4. i did numerous pulls and they all maxed out at 5 lbs. i read in other forums that stock boost is 8psi if this is incorrect please chime in thanks. the vehicle has always been service at the dealer and on time i just purchased the car 2 days ago and i am the second owner the original owner babied the car
Old Jan 22, 2011 | 10:12 PM
Msnickbroderick's Avatar
Actual WIZARD
Broken DV, limp mode, failed n75, etc.
Any codes?
Old Jan 22, 2011 | 10:19 PM
turbo kraut's Avatar
Tech Guru
what year....
Old Jan 22, 2011 | 10:49 PM
Got_A4's Avatar
the year is 99.5 and no codes at all it freaking sucks having boost and not feeling it fawk
Old Jan 23, 2011 | 08:24 AM
chocalotstarfish's Avatar
Super Moderator
Do a boost leak check. Could be something as easy as a hose fell off or a bad check valve.
Old Jan 23, 2011 | 09:13 AM
DanPHines's Avatar
5-7psi is normal for AEB.
Old Jan 23, 2011 | 11:30 AM
ImTheDevil's Avatar
5psi is safety boost.
Old Jan 23, 2011 | 11:55 AM
Mike-2ptzero's Avatar
Correct. 5psi on a stock tune is limp mode. When in limp the ECU just leaves the N75 wide open so the pressure goes directly to the WG actuator which happens to have a 5psi spring. If the N75 fails this will be the same result.
Old Jan 23, 2011 | 02:51 PM
Got_A4's Avatar
is there any way to check the DV to see if it's malfunctioning ?
Old Jan 23, 2011 | 04:14 PM
CCA4's Avatar
The stock DV is plastic and not rebuild-able. I don't know that there would be any way to know that it was bad just by looking at it.
FWIW I have a spare DV if you end up needing one. Just PM me your address and I'll drop it in the mail.
