turbo question
Old Jun 16, 2008 | 06:36 PM
brimhall99's Avatar
Default turbo question
Ok so I think that I need a new turbo, can i just replace the turbo or is there more I should buy, also I have a GIAC chip and I found a ko3s turbo would that work or would it have to be a ko3?
Old Jun 16, 2008 | 09:25 PM
readimag's Avatar
Default RE: turbo question
I would take my money and get a ko4 they are bolt on, just have to buy some intake pluming.
Old Jun 16, 2008 | 09:32 PM
cincyTT's Avatar
I'm make believe
ko3s will bolt right up. It is a little more effiecent than a ko3.
Old Jun 17, 2008 | 01:54 AM
brimhall99's Avatar
ok will the ko3s turbo work with the chip i have, and the turbo kinda sounds like letting the air out of a bike tire when on the freeway
Old Jun 17, 2008 | 10:51 AM
brimhall99's Avatar
also seems like the turbo works when it is cooler outside then when gets hotter i have no boost at all, feels like a geo metro? any ideas on what i should do
Old Jun 17, 2008 | 12:20 PM
cincyTT's Avatar
I'm make believe
yes, buy a boost gauge already. The cold are is already denser so it has to work less. The bike pump is either spooling (if accelerating)or and exhaust leak (if you are crusing at a constant speed). Cant help you much if you dont have a gauge
Old Jun 18, 2008 | 12:14 AM
brimhall99's Avatar
I took it to a shop and he said it was in limp mode because one of the valves of some sort was leaking or air was going in instead of out, does this seem logical?
Old Jun 18, 2008 | 12:43 AM
ghost6303's Avatar
seriously though... get a boost gauge.
Old Jun 18, 2008 | 01:30 AM
brimhall99's Avatar
OK but does anyone have a boost gauge that is on the pillar if so does it look good and where did you get it?
Old Jun 18, 2008 | 05:25 AM
Matt_Iliketurbopull's Avatar
I know the exhaust off the turbo on my car constantly gets loose, making some extra puttering noise.
EvoTillIDie1
Mar 5, 2014 10:42 PM
98A498
Oct 12, 2006 08:06 PM
keko2004
Aug 30, 2006 02:44 AM
zat0rsk1
Aug 17, 2006 11:36 PM
west2005
Aug 13, 2005 06:46 PM
