turbo upgrade help
Old Nov 15, 2010 | 05:40 PM
  #21
Mike-2ptzero's Avatar
Old Nov 15, 2010 | 05:51 PM
  #22
kevace1's Avatar
Originally Posted by Mike-2ptzero
I would suggest the GTRS, you could get 250whp on pump gas even with the stock manifold.
I would suggest a Unitronics tune and you can get that along with injectors and the Elim kit as a package.
So assuming i get this package you outlined, and the custom manifold, i plan on getting a high flow cat and a high flow muffler, and of course FMIC, with the tune to work with 93 gas from sunnoco, how much whp you think i should be getting? and torque? i have the ATW as well..........
Old Nov 15, 2010 | 06:00 PM
  #23
Right around 290-300whp easy.
Old Nov 15, 2010 | 06:19 PM
  #24
kevace1's Avatar
dammit mike, you just made me *** on myself.......now i gotta deliberate whether i should wait for the spring or just get it now........my four ringed hood is looking at me right now saying: "wtf r you waiting for??" LOLOL
Anyways, how does the chip tuning work with you guys? we have to send the ecu in and wait for it with the rest of the package?
Old Nov 15, 2010 | 06:46 PM
  #25
If you go with Unitronic's tuning you have to print out a Uni form, fill it out and ship it and the ecu to Uni in Canada. You are given a RMA PO # to include with the ecu.
Old Nov 15, 2010 | 11:17 PM
  #26
jabba's Avatar
what about the t3 or the t4 turbos they any good? and were can i send my ecu so it could get chiped?
Old Nov 16, 2010 | 12:37 AM
  #27
Nothing wrong with them, to use them you need a different manifold, down pipe, turbo inlet hose and cant use the stock air box. Wont look stock at all.
Old Nov 16, 2010 | 01:22 PM
  #28
zerokiller698's Avatar
Is this tune specific being i'd have to send the ecu out?
if not, i might end up breaking out the credit card
Old Nov 16, 2010 | 06:32 PM
  #29
Not sure what type works with it since it makes power like a GT28r.
Old Nov 17, 2010 | 09:24 AM
  #30
vtraudt's Avatar
Default Custom K04K04
Only way anyone is going to pull 230hp out of a K03 is on race gas and believe me I know seeing that I pretty much have the record on highest hp K03 for the A4 1.8t and that was done on my 2000 ATW. lol
I made about 250hp on 104 octane pushing 20psi with a custom GIAC tune. Funny thing is that was done on the stock injectors and stock 4 bar fpr. Like I said, there is no reason for larger injectors for a K03 on the B5 cars and this is because the B5 has a rising rate FPR while the B6 cars have a static FPR. So the B6 cars need to go larger injectors when the tuners push the boost higher then normal, this is why the tuners offer a stage 1+ (injector) tune for the B6.
Never got a chance to dyno my custom street chip for 91 octane and pushed 26psi, but dont think it was anywhere near 230hp.
Mike,
I have a custom built "K04" from turboconcepts (wheels below, machined/optimized housing), running on stock injectors and what is called a "TAP Stage 2 12.5psi +50HP" chip/tune (FMIC, Carbonio, Test Pipe, Miltek). Turboconcept (sales@turboconcepts.com) used my core; price $200 or so more than 'as new' rebuilt (virtually new turbo).
My boost curve goes to 18.5 psi at 4000 RPM (10 psi at 2000, 10 psi at 6500). No codes (lean or else). What power can be expected from this setup?
Still trying to get a tune that works with this setup (plus injectors and AFPR 3-5 bar standing by).
K04 – optimized by TurboConcepts
COMPRESSOR WHEEL
Inducer: 41.0 mm
Exducer: 54.0 mm
Tip height: 5.6 mm
Blades: 6 double,staged, extended tip
TURBINE WHEEL
Inducer: 44.5 mm
Exducer: 40.44 mm
Blades: 12
10 degree clip
Compressor housing shape-matched to larger compressor wheel and blade shape.
Compressor outlet flow optimized.
Turbine inlet flow optimized.
Calibrated waste gate actuator.
Characteristic:
-Turbine modified for faster spool up and increased flow to work/benefit from high flow exhaust system
-Compressor modified to generate early boost, increased midrange power and high flow at high RPM
