turbo whooshing noise, started today
Old Jul 19, 2010 | 11:06 PM
hauptjr's Avatar
Thanks for the help. Appears that I parked in a bad location. No noticable leakage when I moved the car. (that's the problem with on-street parking).
I have 3 codes:
Component and/or Version: 1.8L R4/5VT G 0002
Software Coding: 16251
Work Shop Code: WSC 63351
3 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-00 - -
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
The P0420 is semi-permanent - every time I clear it, it comes back in 50 miles or less of around town driving. (it never comes on during interstate driving - unless stuck in stop and go traffic).
Took it to a foreign car mechanic. He read the codes to me and said that I need to replace the wastegate inside the turbo, or replace the CAT (I have a p0402 error) - and in a worstcase scenerio replace both. He also tells me that a bad CAT might be causing my occassion p0303 errors.
I'm not sure the best way to go about troubleshooting this. but I can't afford to just replace parts.
Oh - heres another question - in my city, we have mandatory emissions testing. Would the emissions sniff test reveal any useful clues?
It was late - his guys hadnt opened the hood, they just read the codes. I was still at work with someone breathing down my neck (so to speak) so I asked if we could talk about it in the morning. I really had hoped to post this message hours ago. (work, and then other issues/crisises - I just walked in the door 10 min ago).
So advice would be much appreciated!
Thanks!
PS - onepointeighttee - I'll PM you.
Old Jul 19, 2010 | 11:32 PM
onepoint8tee's Avatar
A good mechanic would clear any present codes to see which one's come back. One or more of those codes could be old and irelevant. I kept getting the negative deviation code until I replaced my DV (and dv vac line) and N75 valve. I did them at the same time so it was hard to know which one was the fix. Definitely hold off on the wastegate theory until you've rulled out those 2 things.
Does the 17705 code actualy say "check bypass valve" or something like that? If so then I would certainly just replace it. No point in trying to diagnose a possible tear in the internal diaphragm unless you have a vacuum tool.
I don't think an emissions test would reveal anything. The last code probably points to a lazy 02 sensor.
Old Jul 19, 2010 | 11:51 PM
hauptjr's Avatar
thanks for the input.
I cleared the codes and then drove for a while, so I know those codes are fresh and meaningful.
BTW - does your DV come with clamps or do I just need to buy basic clamps?
Thanks!
Old Jul 19, 2010 | 11:57 PM
You can reuse the 2 big clamps from your DV and the little vacuum line clamp can be replaced with a zip tie. The DV vac line should definitely be replaced when you do this, and I may have enough left over for you if you want that dv. I can even include a zip tie!
FYI you really don't even need a clamp on the dv vac line. It's just sucking and not blowing so the chances of it coming off are pretty much 0%, the vac line is very snug on the nipple, but a zip tie will give a man peace of mind.
VorsprungMonkeyTechnik
Jun 8, 2015 08:37 PM
JamieS64
Jun 29, 2010 12:11 PM
paintballcs
Feb 5, 2010 02:09 AM
BLK_A4
Nov 11, 2007 08:36 AM
KarlMarx
Jun 20, 2006 12:32 AM
