Ugh.. Money Pit
Old Jun 29, 2010 | 04:30 PM
  #21
mikekey's Avatar
Gosh, thought I lucked out, when I bought the car with under 100K and everything ran fine. Then it hit 100K and all of a sudden, Maf, vacuum leaks, bad coil packs, clutch goes....
Oh and a headlight just went out last night, ugh!
Old Jun 29, 2010 | 04:32 PM
  #22
NickBroderick's Avatar
Go buy an '08.
I was looking at buying an '07, but I might go the cheaper route and buy an '02 BMW X5.
Maybe.
Old Jun 29, 2010 | 05:42 PM
  #23
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
I know I've already spent what I spent on the car in mods/repairs. Bought the car for $3,300 with a leaking coolant flange, beat to **** front end (not fixed yet), stock worn clutch (not replaced yet), and broken motor mounts (fixed).
So far I have had the coolant flange replaced, new thermostat installed, coolant temp sensor replaced, turbo oil feed line replaced, new coolant expansion tank installed, motor mounts replaced, snub mount installed, and put Redline full synthetic in it. After I do the front end work and clutch, the power mods will finally start. Gotta get the car running right and tuned up beforehand.
I've been doing little cosmetic mods while I save up for the bigger repairs. The $30 chrome gauge rings are going to end up costing me $250 after I send the cluster in to repair the odometer that just decided to not light up anymore after installing the rings.
Old Jun 30, 2010 | 03:55 PM
  #24
Dallas09's Avatar
Originally Posted by CCA4
Well for starters, I think most of the guys (including myself) were referring to maintenance costs. Personally I've had to replace all but two control arms, a large portion of the wiring harness in the engine bay, timing belt, tensioner, pulleys, cam seals, crank seals, front brakes/rotors, rear brakes/rotors, a myriad of relays and sensors, some $50 exhaust clamps, and about $25 worth of light bulbs. None of that has anything to do with "******* with the car" so much as just keeping it running, safe, and legal.
... +1
Old Jan 18, 2011 | 11:38 AM
  #25
Racerx220's Avatar
i feel your pain i was taking a turn and had my control arm snap so i replaced both driver and passenger control arms and tie rod links then the next day had a hose break replaces all the vac hoses i could get to also replaced the maf , coil packs , icm , all intercooler hoses and turbo inlet hose and now im replacing the turbo coolant flange and still getting misfires on all cyls which i cant figure out why
Old Jan 18, 2011 | 12:21 PM
  #26
dragonrage's Avatar
Mine's been a money pit. I've actually got most of the work it needed finished but I don't want to deal with it anymore so I am trying to sell it.
Old Jan 18, 2011 | 12:53 PM
  #27
McGovs2.7TB5's Avatar
Originally Posted by Munzter
I feel you man. Over the course of the last year I've had my steering rack, MAF sensor, rear differential seals, front end control arms/ tie rods, Airbag control module, and the rear passenger window regulator replaced on top of buying new rims, coilovers, headlights, and a grill. That is just for the past year. There are other repairs I've had to do in the last 4 years of owning this car. I'm not going to say how much I've spent because the guys on here gave me a ton of sh*t last time I mentioned it. And now the pump for my window washer fluid just crapped out on me. I could have easily had an S4 for how much I've spent maintaining this car, but live and learn I guess.
Ya, you probably could've bought an S4 by now, but if think maintaining an A is expensive....
Old Jan 18, 2011 | 01:39 PM
  #28
kriptonik's Avatar
Way to bring back up an old thread.
What ever happened to Mike Key anyway?
And yay - 8,888 posts!
Old Jan 18, 2011 | 02:27 PM
  #29
Staticclism's Avatar
Wow - reading all this makes me think I'm pretty lucky - bought the car with 98k miles, she's got 132k now, and other than some jerk crushing in both of my driver's doors, oil changes, and brakes I haven't had to maintain anything yet.
Old Jan 18, 2011 | 02:32 PM
  #30
turbo kraut's Avatar
Tech Guru
baby kito fell off too randy
FixOrRepairDaily
Nov 19, 2009 07:37 AM
blazinhaze609
Dec 8, 2008 02:26 AM
PandaXpress
Mar 12, 2006 01:06 PM
