Unitronics rumor
w/m/a will raise the oct level of the fuel. so you can run 91 or 93 oct fuel, spary the w/m/a and run a 100oct program. the w/m/a turns on when you reach a preset boost level. so on my evo i have the meth start spraying at 20psi and then it gradually increase the amout sprayed up to 30psi (max boost). i have a progressive unit so it slowly sprays more and more. there are other systems that are on/off (no spray to full spray)
ORIGINAL: FasterA4ThanUrs
little thread jack here:
ive been talking to the guy from unitronics, i think his name is mike, and they will have a chip out designed to run with 630cc injectors... im going to couple that with a 50 trim t3/t4 instead of going crazy with the gt3582r and boring out the block. I asked him if he could get it done in less than 2 months and he said yes... so when my license comes back ill be able to finally drive a quick car daily.
ORIGINAL: ThePaintballGuy
Is it even worth it on a 99.5? I can't use lemmi on mine so I don't know if it's worth it or not.
Josh
Josh
ORIGINAL: Leifer
Brian, I'm looking to hold about 18-20psi, not 25! I don't want to take any chances. But with the w/m injection and lemmi tuning, I'm also going to have a bigger inlet hose, a more secure outlet hose, and a high-flow exhaust mani.
I don't want to push it to the point where I need bigger fuel injectors and oil lines; because at that point I'll throw out the K03 and get a bigger turbo. They seem pretty damn good for the price that you pay; do you have to have it constantly injecting, or is it a timing thing, with when your turbo spikes up that high, your w/m injects so your fuel can burn properly?
you seem to want to put money into your current setup, but if your going BT your just wasting your money. you should just put money into parts that are gona transfer over to your BT setup. and then put the rest of the money towards the BT setup.
yeah, if you have a 00+ car you can use a program from revo call lemmingwinks and adjust a bunch of stuff like timing through a vag cable. i just wish us AEB guys could do the same[&o]
CAB509
Jan 24, 2024 07:01 AM
jthessin
Sep 18, 2014 08:04 AM
