Upgraded SMIC (EBAY?)
Old Dec 5, 2012 | 01:20 PM
AudiTurbo's Avatar
Does my 98 come with a map sensor?
Thanks
Old Dec 5, 2012 | 01:23 PM
CCA4's Avatar
It does not, which means you'd have to plug that bung if it comes pre-drilled, or just not drill it out.
Old Dec 5, 2012 | 03:13 PM
AudiTurbo's Avatar
Ok thanks. Guess i'll have to look for new options for a bigger SMIC
Old Dec 5, 2012 | 05:42 PM
CCA4's Avatar
I believe Apikol is the only company that still sells side mounts. Boost Factory and another one whose name escapes me used to.
Old Dec 6, 2012 | 06:22 AM
AudiTurbo's Avatar
Thank you
Old Dec 7, 2012 | 08:02 AM
AudiTurbo's Avatar
What if I was able to get the intercooler on the left of this picture? Would it work coming from a b5 s4?
Thanks
Old Dec 7, 2012 | 09:34 AM
CCA4's Avatar
It might work, but I don't know how much of an upgrade it would be from your stock core and you'd still need to build custom plumbing. I've heard of B6 guys running dual SMIC's instead of a front mount.
Old Dec 7, 2012 | 10:38 AM
  #18
AudiTurbo's Avatar
Yeah I have heard of people running those too. what is the stock size of my intercooler?
Old Dec 7, 2012 | 11:06 AM
  #19
CCA4's Avatar
No idea, you'd have to measure it. I've never had mine out of the car.
Old Dec 7, 2012 | 11:25 AM
  #20
jonbonesjones's Avatar
Moderator
the TT225hp is a bigger intercooler option. theres a few companies that make bigger side mounts. check these guys out also.
Air/Water IC
cant beat water to air, they should have an option for the stock sized smic and then just pump some coolant through it
AudiTurbo
Dec 2, 2012 03:52 PM
eldri577
May 5, 2011 08:29 PM
thagr81_us
Jan 5, 2009 11:53 AM
Dr.S4
Aug 31, 2007 02:46 AM
wolfdog
Aug 9, 2007 04:15 PM
