Upper control arm question
Old Aug 13, 2011 | 09:59 PM
rplets15's Avatar
Default Upper control arm question
So I have read on many diy's to unbolt the control arm plate from inside the engine bay. But I'm soldering is that going to undo the strut? I really don't wanna mess with that.
Old Aug 13, 2011 | 10:37 PM
ImTheDevil's Avatar
No, there are two additional nuts that secure the strut to the plate.
Old Aug 13, 2011 | 11:36 PM
rplets15's Avatar
Awesome thanks man!
Old Aug 14, 2011 | 12:17 PM
rplets15's Avatar
Ok now that I am working on this, how the hell do I get the plate to move? I have undone all three of the bolts and tugged on that thing like there is no tomorrow but I cannot get it to budge... Is there something I am doing wrong?
Old Aug 14, 2011 | 12:22 PM
ImTheDevil's Avatar
If you have the bottom of the strut free, pull down hard. There's a guide pin up there that sticks through the CA plate and makes it a pain to remove.
Old Aug 14, 2011 | 12:41 PM
rplets15's Avatar
I do not have the bottom of the strut undone... I am just replacing the uppers, and I didnt want to go through all that mess.
Old Aug 14, 2011 | 12:48 PM
ImTheDevil's Avatar
Bottom of the strut is only one bolt. If you leave it anchored and try to pull the mount downward, you're trying to compress the spring by hand - it'll never happen. Pull the strut bolt and dismount the strut. It should make life easier.
Old Aug 14, 2011 | 02:20 PM
rplets15's Avatar
then wont I have to compress the spring to get it back together?
Old Aug 14, 2011 | 02:21 PM
ImTheDevil's Avatar
No because the shock/spring come out together.
Old Aug 14, 2011 | 02:31 PM
rplets15's Avatar
so it comes out and goes back in fairly easily
