vacuum/boost question
Old Apr 25, 2008 | 02:20 AM
SuprA4's Avatar
Default vacuum/boost question
turbo housing line(is that what this is called the nipple on the turbo) yeah well is that boost or vacuum...or boost/vacuum
so ive come to realize that if the lines going to MBC are too long you lose boost along them...so is going as short as possible going to give me more??
any ideas how i can have 23 psi one day and change some stuff then put it back to how it was and now i cant find that magically 23 psi anymore[:@]its like getting to the liqour store at 9:59 and there closed..you know you gave it your best effort and they have it but you cant get it!
its likebangina chick for the first timethen nexttimeyou go to do it shes on her period...
i could prob think of more but its to late but i hope i got the idea through it just isnt tha same once you had the boost
Old Apr 25, 2008 | 04:04 AM
chaos92287's Avatar
Default RE: vacuum/boost question
are you talking about the wg nipple or the banjo bolt on the compressor housing? i've never heard of the length of the line to the mbc affecting anything. but i just used the stock n75 lines that were short anyways. i have experienced different boost when the connections weren't completely tight tho
Old Apr 25, 2008 | 11:26 AM
cincyTT's Avatar
I'm make believe
yes, the line on the compressor housing. It is a boost source for the n75 and wastegate. You have to have the boost source coming from somewhere along where there is pressure. You should only take boost pressure from there (aka swap n75 lines to mbc) or plug that line and take the boost source from the intake manifold (post TB).
Old Apr 25, 2008 | 03:41 PM
pimphell's Avatar
Shorter lines for the MBC would be better wouldn't it?More responsive? That's what I thought
Old Apr 25, 2008 | 07:35 PM
cincyTT's Avatar
I'm make believe
Can i answer this w/o more crap from you...?
Anyways, its just like ic piping, shorter the better.
Old Apr 25, 2008 | 09:48 PM
SuprA4's Avatar
okay so i shortened the waste gate hose and put the MBC (three pronged) into the inlet hose...then cut down on the compression housing hose but im using fuel lines not silicone could the fuel lines not be able to handle the boost and caving in at all?? also some mentioned to me plugging off the inlet hose hole any pros or cons to this??
Old Apr 25, 2008 | 10:49 PM
cincyTT's Avatar
I'm make believe
those forge 3 prong mbc's suck. They are ment to sit in the intake where the n75 is. A normal mbc with an inlet and outlet work much better. A bleed style being the smoothest
Old Apr 26, 2008 | 12:57 AM
SuprA4's Avatar
i got it for $10 bucks so i gave it a whirl.....should i just an EBC or are they a bitch to install??
Old Apr 26, 2008 | 09:00 AM
chaos92287's Avatar
not much harder than an mbc. just a little bit of extra wiring and having to go through the firewall. you can just use a better mbc if you don't want to spend the money on an ebc tho
NHarvey
Oct 19, 2013 06:54 PM
patrixx006
May 6, 2012 11:47 PM
kennyk
Jun 30, 2008 07:14 PM
Stretch1.8
Jan 28, 2008 02:49 PM
reed1099
Feb 17, 2006 11:12 AM
