Boost & Vacuum
Old Jun 28, 2008 | 02:55 AM
kennyk's Avatar
Default Boost & Vacuum
Hello, I installed AWE boost gauge on my TT 180 yr2000 yesterday.
http://www.awe-tuning.com/media/prod...gauge_TT_f.jpg
It's not a chipped car, I only have K&N air intake and Forge splitter valve intalled.
My readings are :
Boost peak- 12psi
Idle vacuum- 22hg
Vacuum peak- 28hg
Do they seem to be OK? Anything unusual?
I am going to have the car chipped in 4 days. The tuner is locally well known guys here in the Netherlands.
http://www.jdengineering.nl/
In terms of above readings, what should be ideal after the car is chipped? If ideal values can't be suggested because it depends on chippers, then what would be the max/min vaules it should go up or down to?
Regards,
KennyK
Old Jun 28, 2008 | 03:05 AM
themysteryman83's Avatar
Default RE: Boost & Vacuum
If only I had such consistent readings... yes those are perfectly within spec for the 180.
Old Jun 28, 2008 | 09:56 AM
bvgoosedd's Avatar
what are the perfect specs for a 225 chipped? revo chip? i peak at 20 psi only in 3rd to 6 gear on the other gears i only get like 16 psi
Old Jun 28, 2008 | 12:05 PM
joshuo's Avatar
Hmm thats odd, mine peaks higher in the lower gears...
I get like 15-20 Hg vac on Idle, haven't found a real pattern in it, but I suspect temperature/Humidity since my peak and hold boost is always about the same.
Not chipped BTW (yet.)
Old Jun 28, 2008 | 12:19 PM
kennyk's Avatar
My car goes to 14psi or so right after I start the engine and drive off. Soon after it never goes above 12psi.
Could it be caused by the temp? I have K&N filter, maybe it's sucking the heated air from engine and that's causing low psi?
I now have more reason to shield the cone filter from engine..
Old Jun 29, 2008 | 04:49 PM
MeanAudiA6's Avatar
why are you guys so worried about heat shielding the cone filters??? get something that will help like a newsouth powergasket plus(ordering mine monday) fmic,WATER/METH these will help fight high temps!!!
Old Jun 29, 2008 | 05:04 PM
achTTung's Avatar
i mentioned making/buying thermocouples the other day. Before you install that gasket, do me a favor, and get a temp reading of your cylinder head, and another after its installed.
I'm still on the fence on whether or not thats a good mod. The car is still making heat, are you just trapping it in your head? that wouldnt be a good thing.
Old Jun 30, 2008 | 07:14 PM
MeanAudiA6's Avatar
why do you think the heat is trapped in the head....if u look at the application its just a spacer i mean the gasket is in turn fighting the heat instead of getting the head hotter....the temps decrease so how do you think the head heats up?
NHarvey
Oct 19, 2013 06:54 PM
patrixx006
May 6, 2012 11:47 PM
SuprA4
Apr 26, 2008 09:00 AM
Stretch1.8
Jan 28, 2008 02:49 PM
reed1099
Feb 17, 2006 11:12 AM
