VAG COM misfire/too lean
Old Apr 22, 2008 | 09:08 PM
Apdl's Avatar
Member
Default VAG COM misfire/too lean
Hi All,
It has been a while and finally got the old Audi checked out.
Here is what it told me...
Fuel Trim; Bank 1 (Multi): System too Lean
P1128 - 35-00 - -
Then some misfire stuff
P0300 - 35 -00 - - - Intermittent
P0301 - 35 -00 - - - Intermittent
P0303 - 35 -00 - - - Intermittent
P0304 - 35 -00 - - - Intermittent
Readiness: 0010 1001
The ceck engine light has been on for a while and when I cleaned the MAF it was gone for like 2 weeks now 6 mo later it is still on
I ordered new plugs and fuel filter
If that dosent work then check for leaks, Coil Packs, O2 sensor cleaning/replacement then I am going to need your help! what is your take on this?
Old Apr 22, 2008 | 09:39 PM
machetetooth's Avatar
Default RE: VAG COM misfire/too lean
I would start by testing your MAF sensor by running to 6500 in second gear while logging your air mass flow rate in the vagcom. Divide the highest flow rate by .8, and that should be around 170 hp. If it's less, somethings up. My xd45 goes bang louder.
Old Apr 22, 2008 | 10:21 PM
Apdl's Avatar
Member
Ok I will see what I can do with that
Thanks
PS. my P22 goes meow
Old Apr 22, 2008 | 10:32 PM
01AudiA4's Avatar
My fist goes faster than your bullets.
Old Apr 22, 2008 | 11:38 PM
Apdl's Avatar
Member
Right...
Now for something constructive...
Old Apr 23, 2008 | 12:08 AM
cincyTT's Avatar
I'm make believe
That is usually a bad primary o2 or vac leak.
Old Apr 23, 2008 | 02:13 AM
Apdl's Avatar
Member
Vac leak would be a whole lot cheaper than an O2
BTW what is the formula for HP from MAF?
Old Apr 23, 2008 | 03:32 AM
david9999's Avatar
I don't have my Bently with me, but in the usual germanic way of doing things AUDI reads out basackward. As I recall, "System too lean" actually means that the control system has exceeded the amount that it can lean the mixture in response to the engine running rich.
Made sense to someone.. Anyway, if someone can look up the P1128 trouble shooting procedure in their Bently, I would bet that it would tell you to change the oxygen sensor.
Old Apr 26, 2008 | 09:10 AM
Apdl's Avatar
Member
Can someone check on this?
Old Apr 27, 2008 | 06:02 PM
ORIGINAL: david9999
Are you pretty sure about this? After a vociferous argument I just had with a 225 hp TT owner who has the same code, I really hope you're mistaken. Not to hijack the thread, but his MAF maxes out at 99 g/s, which is why I thought it was probably the MAF or vac leak making it lean.
Apdl, the hp formula is the one where you divide your peak air mass flow rate by 0.8. I got it from the 1.8t troubleshooting guide thread. GL
campbellpt
Dec 14, 2013 11:43 PM
KJNY2
Sep 25, 2011 10:40 AM
on_6mt
Aug 18, 2009 12:00 PM
919industries
Jun 30, 2008 11:13 PM
