ehh engine codes, misfire and lean mix.
Old Jun 27, 2008 | 10:10 PM
919industries's Avatar
Default ehh engine codes, misfire and lean mix.
Hi i have been looking at this site for a while now and now i have some questions.
Uhm so today i took my car in to get the codes read and it came up with:
P0171 which is a lean mixture code
then it had
P0306-P0304 which are all mis fire codes the 306 being random mis fires and 301-304 is misfires on all 4 cylinders
wondering if anyones had the same issues? or knows what the problem could be
thanks:]
Old Jun 27, 2008 | 10:18 PM
Default RE: ehh engine codes, misfire and lean mix.
oh and my check light is on!
Old Jun 27, 2008 | 11:59 PM
auditech79's Avatar
Does the engine run rough? Can you hear a hissing noise like the engine is sucking in air from somewhere other than the intake?
Most likely its a large vaccum leak somewhere, or you have a broken vaccum check valve.
Old Jun 28, 2008 | 12:16 AM
It runs really rough!its horrible, and there is a hissing noise my dad a mechanic and myself all heard, the mechanic suggested vaccum leak, but was not 100% because he didnt really check it since he was closed and it was a last second look over.
Old Jun 28, 2008 | 04:01 AM
audiprotein's Avatar
Vacuum leak is prolly the common problem, so id say try to fix that and see whats gonna happen.
Old Jun 28, 2008 | 06:06 PM
so i found the leak...it was a vacum advance the little round black thing behind the engine that connects two vacum hoses a seal in that is bad, and getting worse, on top of it all i cant get the part anywhere because the local dealerships are the only ones who have it and they dont open again until monday:[ no fun drives this weekend!
Old Jun 28, 2008 | 11:25 PM
auditech79's Avatar
Those are the vaccum check valves i spoke of, you can get them at both www.ecstuning.com and www.purems.com.
You have a total of 3 of them so change them all.
Old Jun 30, 2008 | 11:13 PM
well i replaced one, and it didnt do a damn thing... where are the other two ocated, i replaced the one on top of the engine directly behind the engine cover in front of the fire wall..
any other ideas?
campbellpt
Dec 14, 2013 11:43 PM
KJNY2
Sep 25, 2011 10:40 AM
on_6mt
Aug 18, 2009 12:00 PM
Apdl
Apr 27, 2008 06:02 PM
