vag-com results
Old Oct 8, 2008 | 07:02 PM
rocky.ca's Avatar
Default vag-com results
here are the results. any insight?
Old Oct 8, 2008 | 09:34 PM
chaos92287's Avatar
leak in your secondary air system causing it to run lean and mess up the reading on your o2 sensor. most likely gona be the crankcase breather hose or combi valve. if there are no leaks then your pump could be bad. if you hear a noise like a vacuum cleaner on a cold start, its the pump
pimphell
Jan 24, 2010 11:06 PM
Mr. Phil
Sep 24, 2009 10:29 PM
Jits7
Jul 7, 2007 05:09 PM
rwood
Nov 11, 2006 07:41 AM
keko2004
Oct 25, 2006 04:39 AM
