water water every where
Old Sep 2, 2008 | 07:44 AM
speedy33's Avatar
Post water water every where
Hi had a new problem, every time it rains lots if water accumulating in rear passenger foot well behind drivers seat, so far I have replaced the pollen filter, removed battery and seat to clean the drain hole, removed and cleaned the pollen filter housing checked the seal in ok condition, but still evey time it rains water level rising, worst so far was 12 litres in 12 hour period of very heavy rain in Plymouth. Any ideas are anybody else sufferring the same
Old Sep 2, 2008 | 07:51 AM
CAB509's Avatar
6th Gear
It sounds like your sunroof drain might be the problem.
if you look around here you should find a DIY on fixing it
Old Sep 2, 2008 | 11:33 AM
Quattro Rich's Avatar
I have this same problem but dont have a sunroof, cant find where its coming from
Old Sep 2, 2008 | 11:52 AM
brrman's Avatar
If you don't have a sunroof you might check your rear window seal.
If you have a sunroof I would definitely point to the sunroof drains. There are 4 drains - 1 in each A pillar and one in each C pillar.
krystallbluea4
Jan 3, 2009 01:44 PM
fcamargo6thave
Oct 12, 2007 07:22 PM
readimag
Sep 4, 2007 12:11 AM
ncsurmy
Dec 4, 2006 08:00 PM
