Weird code..
Old Jul 14, 2012 | 02:17 AM
DanaB6's Avatar
Default Weird code..
My girlfriends 1997 a4 is a 12v 2.8 quattro the car was throwing a random misfire code p0300 a while back and i scanned it again and it gave me p0300 again but this time in the description it showed cylinder 5, the weird thing is its not showing p0305. Any ideas whats going on? Ill also upload a pic of the code.
I just find it odd how before it only gave me p0300 random misfire and then i scaned it again a month later and it giving a more detailed description. Im going to start with the basic and replace the spark plug on cylinder 5 tomorrow and see what happens.
Old Jul 14, 2012 | 07:21 AM
ImTheDevil's Avatar
That's the best first move. On a 2.8 you can't really swap coils around like you can on a 1.8T. If the plug isn't a fix, try a can of seafoam in half a tank of gas. It could be crap in the injector clogging it up and that should help to clean it out.
Old Jul 14, 2012 | 10:05 AM
FASTER's Avatar
Tech Slut
Easier way to clean the injectors out is to simply crimp the fuel return line with block off pliers. The fuel pressure will shoot up and any crud in there should be blasted out.
Old Jul 14, 2012 | 01:19 PM
DanaB6's Avatar
Thanks for the feed back, i was thinking about swapping the coils between cylinder 5 and 6 and seeing how that turns out.
Thanks didn't know about that.
icetab
May 5, 2013 09:18 PM
A6 Quattro V6 30V
Aug 6, 2010 02:06 AM
pathak76
Dec 12, 2007 03:35 PM
MilitantGrunt
Nov 1, 2006 09:16 AM
ByPopularDemand
Oct 25, 2005 12:20 AM
