what is better?
Old Dec 18, 2008 | 02:13 PM
Jc61990's Avatar
Originally Posted by onepoint8tee
Boost for 01 is around 10 psi where 07-00 is 8. 01 gets a k03s which is not the cause for more power, only durability. A more agressive tune was used for the +20 hp. It has nothing to do with the turbo or vvt.
did u mean 97-00 ?
Old Dec 18, 2008 | 02:21 PM
cgroff5686's Avatar
I believe if you get a 99.5 it comes with the aeb 1.8t and also has the one-piece headlights and all the lovely updated things.
Old Dec 18, 2008 | 02:22 PM
onepoint8tee's Avatar
How about you do this, JC. Next time you see a simple typing mistake like that, just assume that I will see it and go back to edit. Replies from you regarding stupid typing mistakes is a waste of your time. I'm almost positive that you have better things to do with your time
Old Dec 18, 2008 | 02:35 PM
A4speed's Avatar
Boost for 01 is around 10 psi and 97-00 is 8.
boost is the same in both AEB and AWM engines.
Audi Engine Info
Engine Code: AEB,ATW,AUG
Model Years: 1997-2000
Compression Ratio: 9.5:1
Horsepower (SAE Net): 150 @ 5700 RPM
Torque: 155 ft. lbs.@ 1750 RPM
ECU: 97-99.5 Motronic ME3.8.2/ME5.9, 2000+ is Motronic ME7.1
DP Size: 50mm (1.97")
Turbo: K03
OE Boost: .6 Bar (8.7psi)
Engine Code: AWM
Model Years: 2001-2005
Compression Ratio: 9.3:1
Horsepower (SAE Net): 170 @ 5900 RPM
Torque: 166 ft. lbs. @ 1950 RPM
ECU: Motronic ME7.1
Turbo: K03s
Old Dec 18, 2008 | 02:51 PM
Where did you get that information? If it's right, then so be it, although it goes against what I always knew to be true and personal experience while driving several stock 01's w/ boost gauges at the dealer. Either way im just saying the turbo isn't responsible for the added power. Wouldn't make any sense to give a more aggresive fuel map and timing without upping the boost a little.
Old Dec 18, 2008 | 03:01 PM
Jc61990's Avatar
im in school.. what else could i possibly do
Old Dec 18, 2008 | 03:07 PM
I thought the short bus arrives for special ed early dismisal by 3pm?
Old Dec 18, 2008 | 03:36 PM
  #18
A4speed's Avatar
1.8T faq from vw vortex.
Old Dec 18, 2008 | 03:48 PM
  #19
Jc61990's Avatar
was late today
