What part is this?
Old Jun 30, 2012 | 08:13 PM
Nevalite's Avatar
Default What part is this?
Noticed this was cracked while changing my valve cover gasket today...
What are those two hard lines? What is the one with the crack and what is that piece? Could I pick it up at the dealership?
Thanks
Old Jun 30, 2012 | 08:40 PM
zaboomafoo1212's Avatar
Not sure what it is, but I know you could easily replace it with some form of hosing for dirt cheap. Just make sure that it doesn't kink and you get two new hose clamps to keep it tight.
Old Jul 1, 2012 | 12:41 AM
hartsoe1's Avatar
Default secondary air pump output elbow
that is $40 at the dealer and you can get it cheaper on line, but that MUST be throwing a code like p0411. use hose clamps to secure. get the part number off of it because they can't easily find it in the catalog without the part number.
Old Jul 1, 2012 | 02:22 AM
ImTheDevil's Avatar
Just use a piece of heater hose. It'll work fine. Probably cost you all of 30 cents for it.
$40? **** that.
Old Jul 2, 2012 | 09:19 PM
Nevalite's Avatar
How hot does that tube get? Should I get a certain heat rating?
Old Jul 2, 2012 | 10:24 PM
CCA4's Avatar
That's the tube between the SAI pump and the combi valve. Doesn't get hot from the air in it, but it does sit right above the turbo. Heater hose would work if you need to pass inspection or somethin but it wouldn't last very long. I'd tear all that **** out completely if you have the option.
Old Jul 3, 2012 | 07:16 AM
derZeck's Avatar
pretty sure I have one in the garage, my work ordered one and ended up not needing it and the Audi dealer would not return it. Shoot me a PM or email at derzeck@me.com
Old Jul 3, 2012 | 10:15 AM
Nevalite's Avatar
CCA4 What do you mean tear that **** out? Is this tube optional?
Old Jul 3, 2012 | 10:21 AM
CCA4's Avatar
It's part of the secondary air injection system. The SAI pump sucks in clean air, pumps it through the tube you took a picture of and into the combi valve on the back of the cylinder head. This supposedly improves emissions on cold starts. In some of the united states, it's illegal to remove this kind of stuff because of emissions inspections. Do you have emissions inspections in your province?
DiscoJaker
Dec 2, 2020 02:16 AM
pzp107
Apr 21, 2014 06:27 AM
AudiTurbo
Jan 7, 2014 02:29 PM
vwjetta4me
Nov 2, 2007 12:51 PM
